Service intervals
Discussion in 'Newbie Forum' started by vishalfiji, Sep 10, 2016.
  1. vishalfiji
    vishalfiji New Member
    FJ
    Hi guys im very new to this forum.
    But would like to acknowledge the various very informative feed backs from you guys.
    Recently i just imported a second hand Prius from Japan to Fiji Islands.
    Just wanted to know when to change the plugs and ATF.
    It currently has 90,000kms.
    Please advice Gurus.
    Also is 5 W 30 good for Tropical Climates.
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    vishalfiji and bisco like this.
  3. vishalfiji
    FJ
  4. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    Toyota calls it a lifetime fluid. That can be a circular definition.
    Recommendations on replacing the transaxle fluid vary widely from 30-60K intervals to never, and it is easy to find those threads on this Board with a search. That schedule does note it on page 25 as part of the 120K service (with spark plug change). No need to go through that debate again here. ;)
    Toyota Prius: How to Change the Transmission/Transaxle Fluid - PriusDIY.com will walk you through the process. Make sure you use the correct Toyota fluid.
    vishalfiji likes this.
  5. bisco
    49,521
    if you plan on keeping the car for a while, change the tranny fluid now, and every 30,000 miles. may help, can't hurt, worth the investment.(y)
    vishalfiji and Mendel Leisk like this.
  6. vishalfiji
    FJ
  7. hill
    8,206
    Welcome !!
    I'd never contradict Bisco's recommendations
    But then again, I'd never contradict one of the PC hybrid tech's either;
    What services you need and what you don't | PriusChat
    So I don't know what to tell you !!
    :p
    Yea, you can't go wrong doing stuff too much ... unless you're short on cash.
