Service Menu Prius 2016
Discussion in 'Gen 4 Prius Technical Discussion' started by Rodrigo Frade, Apr 22, 2017.
  1. Rodrigo Frade
    Rodrigo Frade New Member
    Ireland
    Active
    Hello. Anyone knows how I can get access to the service menu of this car?
    Thank you
    Edited by Tideland Prius: See Kithmo's post #18
    #1 Rodrigo Frade, Apr 22, 2017
    49,694
    what is the service menu?
  3. Mendel Leisk
    38,875
    Service schedule I think.
    Google "Toyota Techinfo", first result (or very close to top) will be likely be Toyota USA Tech Info site. On the front page, is a "tab" saying manuals. Click that, then enter make/year/car (Toyota/2016/Prius), then click search. That'll give you access to view and/or download the US Warranty and Maintenance Booklet (and Owners Manual, and a few others) in pdf format. Not sure if that'll suffice.
    Or on the UK site, is there a "for owners" section, where it shows the schedule? Toyota Canada has something like that, a little clunky. Also, I've managed to cadge older Warranty and Maintenance Booklets (on Toyota Canada site? Forget), but so far not the 4th gen booklet.
    UK owner's manuals here:
    My Toyota | Toyota UK
    Not sure about warranty info though. Closely guarded secrets??
    Rodrigo Frade likes this.
  4. Rodrigo Frade
    Ireland
    Active
    Hi. This thread has some details about what is Service menu.
    Thank you. Was there yesterday. Will re check it.
    #4 Rodrigo Frade, Apr 23, 2017
    RCO likes this.
  5. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,321
    Central Virginia
    Did you forget a link?
  6. Mendel Leisk
    38,875
    Maybe he can't post links yet? (n)
    Prodigyplace likes this.
  7. Rodrigo Frade
    Ireland
    Active
  8. Prodigyplace
    11,696
    11,321
    Central Virginia
    I have not heard of that on the Gen 4. I think Toyota depends more on their TechStream software they only (legally) provide to dealers. There are some OBD2 scanners with "bootleg" versions online that usually run best on Windows XP. Most/all of those versions do not appear to have the explicit Gen 4 support though.
  9. bisco
    49,694
    what is in this menu? following the link to a 7 year old thread, shows (for some) how to get into it, but not what is in there.
  10. Prodigyplace
    11,696
    11,321
    Central Virginia
    I read of some people using that to disable traction control, but the Gen 4 has a button for that.
  11. Mendel Leisk
    38,875
    There's various "service modes" on 3rd gen, and I'm sure there's similar on 4th gen. For example: I recently did a brake fluid replacement, and to do without Techstream software I needed to put the car in "invalid mode". With 3rd gen I was able to cadge a pdf of the Repair Manual. But with 4th gen, I'd suspect your best bet right now would be to subscribe to Techinfo, the pay section, and look up what you have in mind.
  12. Prodigyplace
    11,696
    11,321
    Central Virginia
    Any link to the Techinfo site for Ireland for the original poster?
  13. Mendel Leisk
    38,875
    Don't know. If you google "toyota techinfo" it's the .com site only that comes up.
    I'll attach 3rd gen "inspection mode" instruction, and the brake change without techstream instruction, which shows "invalid mode". FWIW, not sure how applicable with 4th gen.
    #13 Mendel Leisk, Apr 23, 2017
    Mandrade007 and Rodrigo Frade like this.
  14. Prodigyplace
    11,696
    11,321
    Central Virginia
  15. Mendel Leisk
    38,875
    Good find. Maybe google is tailoring my searches to north america? (n)
  16. Rodrigo Frade
    Ireland
    Active
    Usually has different information on the car status such as battery... also more info in the car performance and areas that may need maintenance
  17. bisco
    49,694
    iteresting, i would love to see a breakdown and screen shots. i had never heard of it, and don't see people mentioning it.
  18. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    To get into the service menu on the Gen 4 (UK Excel):
    Press the power button without pressing the brake, which puts you in accessory mode.
    Press and hold the "CAR" button on the Nav and turn the headlights on and off 4 times.
    The service menu should appear on the Nav screen.
    To check the battery voltage from there:
    Touch "Function check/setting" on the screen.
    Touch "Vehicle signal" on the screen.
    Touch any other buttons on the screen at your own risk !
    teeje and RCO like this.
  19. Prodigyplace
    11,696
    11,321
    Central Virginia
    for US Trim Two (no Nav) use the SETUP button instead of the CAR button. The second graphic is after hitting "Next Page"
  20. Prodigyplace
    11,696
    11,321
    Central Virginia
    Correction & clarification:
    Post 19 is the Diagnostics Menu.
    @kithmo missed a step. You need to let the unit boot up before trying the "chicken dance". It also works in Ready mode.
    Holding AUDIO or CAR access the Service Menu. Holding SETUP access the Diagnostics Menu
