Servicing Air Conditioning Systems
Discussion in 'Videos' started by Protec, Aug 21, 2021.
  1. Protec
    Protec Junior Member
    33
    17
    Uk
    Forgot to say….. PAG150 being phased out and hardly seen here.
    life expectancy of majority of vehicles 10-20yrs and tin worm get them. Also, I find the older cars don’t get money spent on them
  2. lech auto air conditionin
    830
    604
    261
    san francisco
    It’s great to hear you got the Fieldpiece kit you just stepped into a new league it might be a while before you get used to the superheat or sub cooling.
    Also nice to stick temperature probes or sometimes you just cannot keep your hands all the time while the vehicle is running to look at the temperature of refrigerant lines.
    there’s two tests for some oils.
    they used to be the old chemical test that would turn colors when we were changing over from R 12 to R134. The chemical test you take a sample you put it in a small bottle that had one chemical then you would add chemical be you would shake it up and down and let it sit and it would turn a particular Color that you would match on the chart to tell you after you’ve done a retrofit how much contamination of mineral oil you had
    The same test is available for POE oil
    then there was a hygrometer that uses a light spectrum prism that would have a shadow cast on what looked like a gun scope with lines for elevation but there was actually numbers and you could read the percentage of a mixed oil.
    if it was Pure POE you would see the line fall on one number if it was pure PAG it would fall on another number if it was a mixed contaminated it would fall somewhere in between.
    this was a method I used to use back in the early 90s when we started doing retrofits from R12. Converted to R134.
    Making your own pulse width modulator is the easiest and cheapest way to go you could do it with a handful of components on your own breadboard.
    Or just use a Arduino is another cheap alternative for somebody Arduino‘s might be a little expensive where you are there only $15-$35 here in the USA but I know you have heavy duty import tax in the UK.
    And now lately I’ve even heard those restrictions were some countries around the world including some companies in the US have stop selling their products to UK because of the taxes in postal fees.
    Yes NAVAC And other companies relabel rebrand and rename their products when they ship them to different countries are used to go to China often with my wife from Shanghai and I will attend the world expos for selling HVAC products and get to see all the products they get purchased and sent throughout the world all the same product just get different names and labels slapped on them.
    I even found supposedly the very large 12 CFM NAVAC Pump that I have that’s nearly $3000 sales over in China with a Chinese brand name and identification tag and label on the motor all in Chinese for $735.
    The MACS mobile app may not be compatible with your models over in Europe you should send MACS an email and ask.
    Solenoid valve is available here and even after market in from vendors directly from China.
    I’m going to the MACS expo convention the last day you go out on the floor and get the meat parts vendors some from Asia trying to sell direct parts kits.
    There’s a company here in United States called ranshu. They have many air-conditioning parts don’t know if they can ship to the EU it would probably be bothersome and extremely expensive.
    But you could probably look at their website just for information purposes and then source your product somewhere else can use ranshu‘s website see what actually is available in the US but not in your country.
    SFO and Protec like this.
  3. lech auto air conditionin
    830
    604
    261
    san francisco
    yes PAG 150 is going to way of the dinosaur.
    only meant for the old York and Tecumseh compressor and A6 Frigidaire when retrofitting them over for the early New remanufactured for 134
    but now all the new manufactured stuff has their machine tolerances for the 46 viscosity
    Protec likes this.
  4. Protec
    33
    17
    Uk
    Good information Tom, thank you.
    yes, I’ve already done my own pwm units, had them about 6 years now x2…… about £6 each ($5) ish…… work well. I did them for automotive diagnostic work commanding other vehicular components manually.
    as for import to the U.K., I can’t get the trublu hose kits here so use the 1/2” rapid evac yellow jacket hoses.
    I saw your recent video on automotive vacuum where you use two pumps.
    Large Navac with the 3/4” trublu silicone hose & the small navac with probably a 1/4” charging hose.
    Q. does it make a difference if you used a 1/2” vacuum hose in place of the 1/4” charge hose and 1/2male-1/4female adapters. Or another trublu 3/4” hose?
    Just a thought and the rationale is, I use the 1/2” rapid vac hose to the manifold then 1/2male-3/8female adapter to get it on the manifold. It does make a difference even though I’m then pulling through the1/4” high&low hoses.
  5. Protec
    33
    17
    Uk
    Oils……
    PAG46/100 & PAG46e/100e the two most common lubricants in Europe. Unless Hondas.
    PAG -e oils are just a refined version of PAG-non-e
    The important issue here (and relevant to this EV&Hybrid forum) is that there is no test I’m aware or to tell technicians what oil or blend they’re dealing with on first contact with the car like we both have for refrigerant.
    I send all information from my kit to the client, inc photo of the neutronics screen and datalog from joblink but it infuriates me that I can’t tell which lubricant I’m dealing with no matter what it says on the stickers for manufacturers recommendations.
    last workshop could have used non EV safe oil at 10% add, it won’t show on any test.
    this industry is unpoliceable, thoughts out loud here, when will uneducated clowns be held responsible.
    Superheat, subcooling
    I tend to take those a bit loosely, cars over here are compact to say the least, I can generally find a good reliable superheat source but struggle to find a good subcooling source due to how the pipework are routed on the car, it’s good though. The algorithm on the sm480v could possibly be adapter for this????? Maybe?
    and
    I’d also like to see the joblink software user alterable to enable me to edit the probe label names. I know what they mean but the client often asks “what’s the source temperature & what’s the return temperature “ because fieldpiece are missing a huge automotive chunk of opportunity imvho.
    If I could edit them to “ac output” or similar, it would cut the clientele confusion.
  6. lech auto air conditionin
    830
    604
    261
    san francisco
    It makes a slight bit a difference a little faster in the beginning.
    But once the system gets down to the micron level that’s where little hoses and big hoses or big vacuum pump and little back and pump almost do the same amount of work.
    you just get down to a lower vacuum quicker it’s like using a Hummer to pull out a weed in your front yard get it done faster.
    Protec likes this.
  7. lech auto air conditionin
    830
    604
    261
    san francisco
    Yes if either Fieldpiece or measureQuick would allow somebody in the automotive to develop their software geared towards Automotive to let them get into the source code so they can alter the parameters and change the way the software works more geared towards Automotive that would be very helpful.
    The only problem with the Automotive cars very too much too many compromises had to be made that force the system to work on your severe situation that would never happen in a normal world for a heat pump at your home that sits still under slow-moving temperature compared to a car that’s a heat pump driving down the road at 60 miles an hour that could drive from being in the shade on the north side of the mountain where it’s cool 10 minutes later pass through a tunnel and be on the west side of a mountain or south side where it’s hot and sunny
    with the fan systems that vary the air over a condenser from either pulsating or constant on or variable makes the superheat and sub cooling fly all over the place not steady.
    It’s too difficult in automotive on top of that you cannot do it at idle because the compressor is not working insufficient RPM range
    and you cannot do it with the vehicle still with no airflow flowing over the vehicle because the condenser was not meant to operate in that mode for efficiency.
    Because of the negative pressure created in front of the condenser by the rear fans behind the radiator pushing the hot under hood engine heat wraps and rolls around the front from underneath in any little tiny openings and cracks around the sides of the radiator sometimes even the top of the radiator and then suck back in hot heat re-heating up the condenser when the car is sitting in the store giving you false test results
    and just a simple fan is not sufficient to blow air over the front of the car because you have to have a linear fluid flow of air
    so you would need a fan for multiple large fans literally going through ducting very large ducting we’re talking three or 4 feet high 6 to 8 feet wide
    then inside the ducting you would need straightening veins where you break up the airflow to make it linear and the ducting would have to be 3 to 5 times longer than it is wide it’s a physics thing with airflow to get it straight now so it’s non-turbulent.
    Then this air would be directed at the front of the car to put a front pressure on the front grill at the same time having airflow over the hood and underneath under the engine to make a negative draw to bring the air rearwards from the hot air engine compartment instead of rolling around front words.
    And any test performed to take measurements have to be performed with the hood closed when you’re using the fresh air mode pulling the air in from underneath the windshield so you don’t bring 140° or 160° air up from the engine compartment right down into the evaporator.
    This is where the remote for your peace gauges come in good because then you don’t have to run hoses up underneath the wheel well or from underneath the engine and then attach them to the fittings
    But you have to wrap the Fieldpiece sensors in rags to act as an insulation against radiant heat from the exhaust manifold in the high under hood temperatures and then put tinfoil around the rags with the reflective side facing outwards
    Because when the sensors get too hot they shut down (ask me how I know)
    he’s are all methods and airflow fluid dynamics and thermal dynamics stuff my father taught me when I was too young to fully understand and comprehend but I did grasp base knowledge at a very young age without math.
    unfortunately this trade was never meant to have anybody smart actually wanting to know how to diagnose and test things to fix stuff.
    This industry was more geared for parts monkeys see part broke take part off open box replace with new part.
    The one thing my father taught me when I was young was he told me to look at all the mechanics trying to look at pressures and temperatures with an engine at idle now I was a mistake number one
    Or even if they did ever read anything and bring the speed up to 1200 RPMs 1500 RPMs 1800 RPM whatever the manufacturer specified for that particular vehicle as a testing speed for the air conditioning their mistake is they had hood up while it was in fresh air mode taking in 140F or 160°F air giving them completely False superheat or sub cooling or pressures.
    But with today’s variable displacement compressors in the way the fans work totally just throw superheat and sub cooling basically out the window
    But take for example Toyotas techstream software on the newest Prius you put it in a C test mode where they use their pressure transducers in temperature sensors and they have a firmware or base in hardware software that’s the compressor RPM and fan speeds into a test mode to determine if the refrigerant is significantly charged or not
    This is what all cars need for the manufacture to do
    just like on the large VRF Heat pump and heat recovery unit in commercial buildings they have a test mode where you go into the software and they use the onboard transducers Heat pump and heat recovery unit in commercial buildings they have a test mode where you go into the software and they use the onboard transducers In temperature sensors to test the system
    Protec likes this.
  8. Protec
    33
    17
    Uk
    Totally agree Tom.
    I’ve not had the joblink probes shut down on me yet. I do try to wrap them.
    just watched your stickystuff video clogged your neutronics analyser, another real annoyance.
    dab the valve prior to testing, get some on your gloves, finger&thumb and dab the finger and thumb together a few times, the stick sealant reacts with air and clogs, I can generally “feel” it ….. hope that helps
  9. lech auto air conditionin
    830
    604
    261
    san francisco
    I do get lazy about depressing the low side trailer before hooking up my refrigerant analyzer.
    Usually when those customers themselves or the customers took it to a shop that uses the little cans that also contain lubricant with leak sealant and they don’t have just one can squirted into their car they have 23 or four cans and they have so much lubricant as soon as you start recovering out the low side tons of oil start coming out because it’s so over oil be in the system
  10. Protec
    33
    17
    Uk
    Horrible isn’t it.
    had a 2005 2.5tdi pd VW Transporter T5 AXE engine code in today dual evaporator. 950g (+or - 50g) recovered 340g
    Lowest vacuum I could get was 540um vacuum running and 850um static settled.here in the U.K., temp22, humidity was 87% dropping to 54% roughly sea level inland
    After recharge, front vents 5.5degC-6.5degC, rear passenger vents 12degC
    Rear evaporator liquid and vapour lines buried under covers so couldn’t get a clamp on them,
    heater; air conditioning; for passenger comparteme... Transporter (TR) 2006 year Volkswagen EUROPA 820010
    line at item 5 is where the floor is, take out item 18 (rheostat pack) and can see the rear evaporator
    took all day, easy? I don’t think so.
  11. Protec
    33
    17
    Uk
    Brilliant
    R134a not flammable???????
  12. Protec
    33
    17
    Uk
  13. Protec
    33
    17
    Uk
    Have you any thoughts on it please?it’s too new here in the uk
    Just wondered if you have heard any feedback at all please
  14. lech auto air conditionin
    830
    604
    261
    san francisco
    R134a not flammable
    what you see in the video is your 12a (brilliant)
  15. lech auto air conditionin
    830
    604
    261
    san francisco
    Those are both excellent pumps manufactured by the same manufacture they just change the name a little bit for the European market like they do around the world with all their products.
    The advantage of the DC motor pump is that if the wiring is old in the building small gauge and it has a high voltage drop on start up a normal big pump will stall out and just come in overheat and blow a circuit breaker.
    The DC motor starts off inverter driven at a slower lower speed so it doesn’t have a high inrush current so I can start easy.
    I have the smaller brother of the 12 CFM DC driven vacuum pump I have the CFM version.
    I also own the larger industrial vacuum pump 12 CFM actually capable of going down to 3 µm.
    The DC motor vacuum pump you can run and start on the extension cord that would normally be too small to run the larger industrial vacuum pump.
    so for you I will recommend the DC motor driven vacuum pump.
    The other industrial grade vacuum pump is for somebody like me who literally runs it from morning tonight every day 365 days a year.
    I leave my vacuum pump on jobs running 24 seven over the weekend when leaving the job Friday night and showing up back to work Monday morning.
    I’m trying to achieve a ultra low vacuum to help my customer systems to be is moisture free as possible. And because I’m a business that charges hourly I need this to happen as fast as possible at $185 an hour every minute cost money.
    That is the only reason I have the larger white 12 CFM industrial vacuum pump.
    definitely not recommended for the do it yourself person. Especially since it cost near $3000 for this vacuum pump
    That first vacuum pump you selected I see many of those burnt out and shop high failure rate it’s good for a backyard do it yourself person for a couple jobs or not important jobs.
    A lot of the mechanical shops who are cheap I see by those eBay specials . And when they start losing their vacuum capability the shop doesn’t even know that they’re using a vacuum pump that is no longer working any good it’s spinning it’s making noise but not drawing a good vacuum
  16. Protec
    33
    17
    Uk
    Thank you again for you advice, I really appreciate it.
    I already have the fieldpiece vacuum pumps. They also have dc motors. 15micron.
    I cannot get the industrial 3micron pump which you use here in the uk , if I could source one I’d probably have it. (Trutech Tools will not ship abroad to the uk)
    yes…… navac=usa…… navtek=uk both same……. Navac/navtek also make the “value” range of hvac products here in the uk.
  17. Protec
    33
    17
    Uk
    priuschat put the “vacuum pump” link in I didn’t realise and would never get a cheap nasty pump hence the navtek 12cfm 5micron which I thought I’d described.
    Sorry if this has caused confusion
  18. lech auto air conditionin
    830
    604
    261
    san francisco
    Understand
  19. Protec
    33
    17
    Uk
    Got this Tom
    NP12DM NAVAC 12 CFM, Industrial Grade, 5 Microns, DC
    all good, thanks for your input mate.
  20. Protec
    33
    17
    Uk
    Im absolutely loving your refrigerant sight glass videos Tom, absolutely Fantastic mu friend, nothing short of brilliant.
    As a side note, just about everything I buy has some kind of sealing issue whereby I’ve got to reseal the manufacturers seals.
    Love em, keep them coming
