Servo Motor
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusC12, Jan 14, 2026.
  1. PriusC12
    PriusC12 New Member
    Las Vegas Nevada
    is it possible to replace the servo motor without removing the dash board? Or is it possible to move the servo to cold position? After I use the heat the servo motor won't go back to cold. Thanks you.
  2. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I've heard of people cutting access holes in the dash to get in there, at least in other car models. Never head of anyone trying that in a Prius c though.
    PriusC12 likes this.
  3. PriusC12
    PriusC12 New Member
    Las Vegas Nevada
    Thanks for the input. I'll check on that.
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I wish you luck, it's not a fun situation. Virtually every car model with automatic climate control has this same setup, and has the potential to run into the same problem you're having.
    Most of them also require the whole-dash-out to fix a bad servo.
    If you do find an easier way, maybe let us know?
  5. ChapmanF
    19,038
    I don't know about the c, but in some Prius generations there has been a big difference in difficulty depending on which of the servo motors needs to be replaced.
    Gen 1 and gen 2 had at least one or two of the servos kind of practically accessible from the driver's footwell. The air inlet servo, fuhgeddaboutit.
