"Set" button under steering wheel
Discussion in 'Gen 2 Prius Technical Discussion' started by KieferSkunk, Apr 23, 2007.
  1. KieferSkunk
    KieferSkunk Technogeek
    60
    25
    Seattle Region
    Hi everyone. I'm new on this forum, and I just bought a new '07 Barcelona Red Prius (Package #5 / NL - got Nav, didn't get leather). I upgraded from an '05 Driftwood Pearl (Package #9 - Nav) and sold the older Prius to my father-in-law, who is enjoying it immensely. :)
    He asked me what the "Key" button under the steering wheel was for, and I learned through this forum that it enables/disables the Smart Key/Smart Start system. Thanks for the info! I discovered that in my new '07, there's another button in the same spot, printed with a roundish shape followed by the word "SET". Any idea what that button is for? I couldn't find any topics on here that discussed it, and I also don't recall seeing anything about it in my manual (or don't know where to look).
    I haven't tried pushing it yet. :)
    Thanks!
  2. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    <div class='quotetop'>QUOTE(KieferSkunk @ Apr 22 2007, 10:37 PM) [snapback]428194[/snapback]</div>
    This button is used to RESET the Tire Pressure Sensor System.
    The following post explains about this system:
    http://priuschat.com/index.php?s=&show...st&p=355951
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Welcome to PriusChat, KieferSkunk! Like TAO said, it resets the TPMS, so you want to check and adjust your cold tire pressure before pushing it. This is important if you decide to run a higher tire pressure, as some members on here do. Set the pressure in your tires, then set the TPMS. If you change tires, there is another reset, in the setup menu of the Nav menu.
    24gzerancr likes this.
  4. KieferSkunk
    60
    25
    Seattle Region
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 23 2007, 02:05 AM) [snapback]428214[/snapback]</div>
    Thanks muchly! :)
  5. Warwind
    Warwind New Member
    137
    Hedgesville, WV
    I pressed it, and a little sign on the dash lit up saying, "Please Do Not Press This Button Again"... :p
    I just noticed this button over the weekend and didn't know what it was, so thanks for asking the question!
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(Warwind @ Apr 24 2007, 10:51 AM) [snapback]429023[/snapback]</div>
    Pressing it again after receiving this message arms the ejector seat. :D
  7. rashidnazirsons
    rashidnazirsons New Member
    faisalabad
    please tell me the procedure of remote key along with under steering button?
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The SKS key button under the steering wheel is used to disable the SKS. In other words, if you don't want your smart keys to work, press the button under the steering wheel.
    There are not many reasons to do this, so generally this button is not used.
    It can be used to help save your 12V battery if you park your Prius for an extended period, such as at an airport.
    Tom
  9. cnschult
    cnschult Active Member
    772
    97
    Michigan
    That button is intended only for Bruce Willis to push when he's on an asteroid.
  10. Prius Newb
    Prius Newb Junior Member
    26
    Ft Lauderdale, FL
    So I went away for a few weeks and had a friend come by to run my Prius and check on the house. I DID NOT disable the SKS with the "Key" button. He claims he came by two days ago and the car started fine. Today, car wouldnt start, got it started with a "jump" then had to jump it a second time later in the day.
    1 - Does disabling the SKS make a huge difference to the 12v battery?
    2 - Recommendations on recharging the 12v battery (its about 1 year old)
  11. bisco
    51,154
    doesn't sound right. i go away every winter for 5 weeks, leave everything on, and the battery is fine when i get home. could he have left a light on or door ajar?
    you need a trickle charger for sealed batteries. 4 amps i think. there are threads here with specific models.
    what did you replace the oem battery with, another toyota?
  12. Prius Newb
    26
    Ft Lauderdale, FL
    i think he left soemthing on. cant be sure, but i'm guessing after he drove it and put it in garage it was on battery power. didnt hear engine running so he got out and walked away leaving something on.
    was replaced with an aftermarket yellow top battery. I believe Optima brand, but not 100% sure
  13. bisco
    51,154
    he couldn't have left the car on, or it would still have been on when you got home. plus, that wouldn't kill the battery. could be a door not completely latched. if it's an optima, you can check their website for charging info, they will take a faster charge rate than the oem yuasa battery. maybe 10 amps, not sure though.
    it's also possible you got a defective optima. recharging and check will confirm either way.
    a lot of people are using ctek chargers.
    #13 bisco, Jul 5, 2016
