Setting or hack to keep the car from moving with the port lid open?
Discussion in 'Prime Accessories and Modifications' started by Randall Henderson, Nov 24, 2021.
  1. Randall Henderson
    Randall Henderson New Member
    Warrenton Oregon
    Mine is a 2021 prime with the basic (not smart lock) charging door.
    Is there a setting or hack to prevent the car from moving if the port lid is open?
    Or even a way to have a loud audio alert rather than just the visual one on the dashboard.
    There's a visual alert if the port lid is open but you can still move the car. I'm concerned about missing the alert and taking out the door backing out of the garage since it sticks out beyond the edge of the narrow garage door opening.
  2. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    As far as I know, the charge cord must still be connected in order for it not to start up/move. There is probably some way but I have no idea. I would say just make sure and be exrtra careful in the meantime. Maybe even put a little post it note on your screen and leave it there thats says "CHECK CHARGE DOOR"
    52,391
    not that i have read. maybe jury rig a spring to pull it at least closer to the body when you take the plug out
