Setting TPS to the correct position?
Discussion in 'Generation 1 Prius Discussion' started by JJLINK, Jul 30, 2011.
  1. JJLINK
    JJLINK Junior Member
    2002 Prius
    I
    Can anyone tell me how to set TPS to the correct position? I removed it while cleaning the throttle body, and now I can't seem to get it positioned correctly. The engine keeps revving its self while in park. I read AllData's instruction about starting with a 15 degree rotation to the right and then adjusting it using a Toyota hand held meter (which I don't have). Any ideas?
  2. Patrick Wong
    18,200
    6,471
    It's unfortunate that you removed the TPS as that was unnecessary. The spring-loaded throttle shaft will pivot 90 degrees and you can rotate this by hand when the car is IG-OFF. This gives you good access to clean the throttle body interior and throttle plate.
    I suggest that you will need to have your local Toyota dealer service dept adjust the TPS correctly.
  3. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    A couple of options here. TIS has a procedure, but it does require techstream.
    Buy a used throttle body and bolt it on.
    Go to a dealer or independent toyota shop and have the set it. (towing+labor =??)
    Eric
