Several issues and what I think they mean...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dvancleve, May 29, 2017.
  1. dvancleve
    dvancleve Junior Member
    45
    Chandler, AZ
    Howdy folks.
    My family's 2006 Prius has several minor issues. I did some poking around in here, and I think I know what the probable solutions are. There is a ton of stuff in here though, and I'm hoping someone can confirm my conclusions.
    First off, my MFD does not always respond appropriately. Generally sections of it seem to work, but not everything. I just replaced the 12 V battery for the second time (Exide AGM), I was hoping that was the issue, but it doesn't seem to have changed anything. This means replacing the MFD, correct?
    I think the other two issues may be related. The cruise control has never resumed reliably, and at some point the steering wheel recirc and defroster buttons on the lower right quit working. I'm not sure when, I never really use them much. All the controls on the left side of the wheel work fine. I believe this all points to the spiral cable being bad?
    I think if I can get all the steering wheel controls working reliably, I will leave the MFD alone until it gets really bad. The car is pretty much on beater and kid driver duty, 150K miles and on the second hybrid battery.
    Thanks, Doug
    49,693
    i think you're spot on, let's see what others have to say. all the best!(y)
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Main battery usually last around 200k. But if you take off like a bat out if hell it's harder on them.
  4. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Yep, spiral cable. Use your VIN to get the right part number--there are different button configurations.
  5. dvancleve
    45
    Chandler, AZ
    The original hybrid battery croaked at about 94K, it was replaced under warranty a few months before the warranty ran out. I'm hopeful the second one will last a lot longer than that…
