SF Bay area: PG&E do I need to get into a different rate plan?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 3, 2012.
  1. SJ PiP
    SJ PiP Member
    190
    35
    pge website finally fixed the missing the hourly usage/cost bars for e9a
    CharlesH likes this.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My full month's worth of charging, 29 days equals to a $77 electricity bill. This compares to last month's 10 days charging $73 bill. and the previous month of zero charging, I didn't have the PiP yet, at $57. All three bills says $0.15 average kwh. But since it's tiered, most of PiP charging is tier 2. I have no idea what I am paying in electricity for the PiP. I just know it's in the neighborhood of $20 a month +/- $5. To me, that means about the same as gasoline.
  3. SJ PiP
    SJ PiP Member
    190
    35
    good info. time of use + tiers is complicated, but was able to confirm pge bill within a few cents using above algo and raw hourly usage data. (y)
  4. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Most people can easily "save" enough kw-hrs in a month to lower their bill by the amount that it takes to charge a PIP everyday...and you don't need to spend $10K - $20k for solar to do it.
    Here is one example: you can now buy LED downlight conversion kits for $20-$30 each. HD just had these on sale (that includes a PG&E rebate). These are for the 65w can lights in lots of kitchen ceilings. Lets say you have 8 of these and they are on 6 hrs per day (average over the year). You now spend 8 *6hrs * 65w * 365d/yr or ~1100 kw-hrs per year. With the 10w-15w replacement that would be ~175-260 kw-hrs per year or 840-925kw-hrs saved. That is enough for 280-308 full PIP charges.
    Then the LED lights also save 3 more ways: 1) pretty much never need to be replaced; 2) seal the leaky can lights so you use less heat or A/C (this is probably the biggest saving); 3) lower your tiered pricing for PG&E.
    Note that these are not just replacement bulbs, they seal up the hole, IMO look better and take just 3 minutes to install.
    Just one example (I saw 3-4 different versions in HD and 2 in Lowe's)
    6 in. White LED Recessed Lighting Retrofit Trim (T85)-CER673WH at The Home Depot
    Previously these have been $50 - $100 each.
    Mike
  5. lensovet
    2,615
    496
    Burlington, NJ
    My problem with the vast majority of LED bulbs on the market today is that they are either as efficient or even LESS efficient as a comparable CFL, while costing 3-5x the price. To date, the only LED that makes financial sense from what I have seen is this bulb: 10.5-Watt (60-W) A19 LED Bright White (3000K) Light Bulb-420240 at The Home Depot
  6. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    While the LED bulbs aren't necessairly more efficient than a comparable CFL, and are more expensive than a CFL, they a) will last a lot longer, b) their light output doesn't fade with time, c) they don't have mercury in them, making disposal of them a whole lot easier than a CFL & d) they are more easily dimmed than a CFL. Prices of LED bulbs have been steadily dropping.
    My main complaint is that no one seems to make an LED bulb in an intermediate base size. Everything seems to be candelabra or medium bases.
  7. lensovet
    2,615
    496
    Burlington, NJ
    They will last longer but still not enough to offset the cost. I can get 4 60-watt equivalent CFLs in Home Depot for like $6. An equivalent LED will cost $20, use the same amount of energy or even more, and last as long as maybe 3 of the CFLs.
    Dimmability is great bit I have yet to live in a house that actually has dimmers.
    My point was just that today, they are impossible to justify on economic terms. The bulb I linked, at 10.5 watts, is the only one that does, and even then, the payback period is basically 1-2 years before the bulb dies.
  8. 3PriusMike
    3,101
    2,419
    Silicon Valley
    Due to the price issue and efficiency...that is why these LED downlights are a clear winner. They add the fact that they seal the air leaks in all can lights. This saves on heat and A/C as well. Note that these are not just screw in bulbs. They are an entire fixture that goes inside the can and provide new trim. But they take just a couple of minutes to install. They can take a leaky non-IC rated can and seal it.
    Mike
  9. lensovet
    2,615
    496
    Burlington, NJ
    That's fair. In my particular case, I don't have a single place where I could put them.
  10. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    If you use this calculator:
    https://www.pev4me.com/electric-vehicle-calculator/
    you can link to your PG&E data or you can download the "green button" data from PG&E and then upload it to the pev4me site. Detailed instructions are on the pev4me site, it's hard to find the download link without them.
    [edit] As far as I can tell from this discussion and the PG&E website, this is the only way to compare the E-9A plan with your current plan using your own data.
    It tells me that I'll save about $300 per year by switching from E-1 to E-9A
    If you click on "details" it gives you detail about the effect in the summer vs. winter.[/edit]
  11. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Thanks for the info. I checked it out, for me also results came out as saving $350 per year with E9-A, however, I felt that it is probably little high. Since I have two bills with PiP, my additional bill seems to be just < $20 ((0.16 * 3) * 30), where as the website details shows it up as additional $30 per billing cycle. So, I guess my savings would not be as high as $350 but probably around $100-$150, still it is a savings. So, I am going to switch and see how it works for me. Also, for what ever reason, PG&E's website itself says that I am better off with "time of use" rate plan (without the EV), so I guess I wouldn't get burned by going to time of use plan.
    delrey likes this.
  12. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Here are my bill details after rate change from E1 to E9. It is complicated bit when you exceed your quota (as you can see the spike in the bill at the end of my cycles). Still, I need to keep an watch for the summer, where there are more tiers (right now there is no "peak" tier)
    3PriusMike, lensovet and mmmodem like this.
