Shaking at low battery & winding down noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AshliJ527, Jan 27, 2024.
  1. AshliJ527
    AshliJ527 New Member
    Glen Allen Va
    Hey there! New here, looking for help for a dear friend. He has a Prius 2010 and it’s been shaking upon acceleration for the last two days. I’ve also noticed a winding noise when he slows, which I never noticed before. We ride to work together every morning so I’m in the car 6 days a week for about an hour. There’s appx 209k miles on it, he just replaced spark plugs, sway bar and tires within the last month, quite a while before this all started. Any help or advice is graciously appreciated!! Bless you all!!!
  2. AshliJ527
    Glen Allen Va
    I’ll also note that the battery seems almost full, one time it was low and it shook quite a bit worse. Hopefully this info helps point towards the culprit!!
  3. Tombukt2
    Tombukt2 Senior Member
    13,579
    2,450
    Durham NC
    Sounds like your engine is having head gasket problems the fire is getting put out and your battery may be original and it's getting on up there in years and mileage and these two things combined can wreak havoc on many folks's mind.
  4. CR94
    CR94 Senior Member
    2,769
    1,213
    Northwestern S.C.
    Clogged EGR passages in the intake manifold can cause rough running during moderate acceleration, or when the engine is charging the battery. Have they been cleaned yet? If not, at 209k, it's past time for that maintenance routine (which Toyota doesn't admit is needed).
  5. Mendel Leisk
    42,041
    Assuming the EGR system has never been cleaned, and the miles, probably blown head gasket.
