Shaking during acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GForee, Nov 11, 2013.
  1. GForee
    GForee New Member
    I am a brand new Prius owner, but not of a brand new Prius. Purchased a used 2005 on saturday (11/9). Everything was GREAT all weekend long, but this morning, the car started shaking as I was driving it down the road. I drove my 55 mile commute, parked and took my son in to preschool, and left the school heading to work. The shaking started when I left the school. As I was driving (around 45 mph, accelerating to 55 on flat road), the car had some definite shaking... like a sputtering shake, but there was no sputtering noise. I have looked on here and found several shaking while idling issues, but none like this one. No engine lights are on. Could this be a balancing issue rather than an engine issue? Or possibly a joint? Do these cars even have a flex joint?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    It is going to be difficult to pin point that problem from just the description. I think you will need to get someone with expertise to observe while the symptoms are evident. It could be tire damage or wheel balance. Some front end problems, like a shimmy due to loose ball joints, occur at specific speeds.
    It could be propulsion related, if it really only occurs under acceleration and is not speed dependent. That would indicate something related to the spark plugs (misfiring), or throttle body, or fuel mixture. Those things usually throw DTC's, so with out warning lights it is only a guess.
    razdan and ursle like this.
  3. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    If you add your location to your avatar, perhaps we can recommend a local shop or member to assist you.
    Welcome to PriusChat!
    SFO likes this.
  4. GForee
    GForee New Member
    Update: the shaking/sputtering happens after I have been up to highway speeds and then slow down to city driving. It's a rough shudder back and forth. Now the engine light is on. Got home and my husband got in to drive it. Engine light flashed at us as soon as we got out of the driveway. Checked fluids and oil was nearly dry, by we haven't noticed a leak. Put in the 2 quarts we had and it still isn't showing up on dipstick and is not leaking out. Could low oil be the problem? It was fine Saturday and yesterday!
    Sidney, Arkansas
  5. nh7o
    1,686
    340
    Hawaii
    There are many reports of high mileage Prii using oil. Like every other engine ever made, there is a need to check the oil on a regular basis. The car was likely low on oil when you got it, if it is not something you have checked already. There is a warning that appears on the MFD ("Problem" is displayed) if low oil pressure is detected.
    Now that you have engine lights on, the codes can be read by a suitable OBDII reader. You can try the generic reader which is available at some car parts stores, which can read standard engine codes but won't read Prius hybrid related codes. Otherwise, paying at Toyota for a scan is an option. Please report the codes here for the helpful folk to comment on.
  6. bisco
    52,883
    how many miles on her?
  7. GForee
    GForee New Member
    Just went out to drive Pollyanna (car's name) after putting oil in. I only went 5 miles down the road and back, but no shaking so far! :). Could oil have been the problem all along? FWIW, the dash panel never read "problem". Still going to have code checked tomorrow. Nearest dealership is 55 miles from home. :(. She has 107K on her.
  8. bisco
    52,883
    that's kinda young for that much oil burning, hpefully, someone simply forgot to add oil. top it up and keep a weathereye on the level. who did you buy it from, any maint. records?
  9. razdan
    razdan New Member
    Lafayette, Louisiana
    My 2007 Prius with 165k would burn oil. Some of the things it would do when accelerating is what you are describing. Also when ever I would drive over 55MPH the warning light would come on for a few seconds and then turn off.
    Does the engine make a rattle noise? (that's what mine would do)
  10. nh7o
    1,686
    340
    Hawaii
    The usual symptom of low oil is that during a change of speed, or during a sharp turn, the oil intake pipe in the sump is left high and dry while the remaining oil is piled up in one side or the other of the oil pan. This produces a brief warning until the oil begins to pump again. However, at this point there is damage happening to the aluminum engine. So it is critical to always check the oil. Weekly is not too much, until you get a feel for what the car is using.
  11. GForee
    GForee New Member
    Well it is shaking again this morning. Low speeds after being warmed up 15 miles or so. It's on straight flat road not just curves!
  12. GForee
    GForee New Member
    Add idling to the mix…
  13. GForee
    GForee New Member
    It's it started shaking while idling when the gas engine was running. Not during kicking on or off.
  14. GForee
    GForee New Member
    Got the code read:p0301 cylinder one misfire.
  15. GForee
    GForee New Member
    P0301 cylinder one misfire.
  16. nh7o
    1,686
    340
    Hawaii
    Cylinder 1 misfire is something that has also been mentioned often enough here. First take a look and make sure the spark plug recess is completely dry with no water accumulated. Try new spark plugs if they have not been changed already. At that age you are due for a new set. If no joy then swap the igniter coils to see if the problem moves to another cylinder. Last is to clean, or even replace the injector 1.
    If you pull spark plug 1 you may find that it is oily, which might give an indication of where your oil is going. Also, check or replace the PCV valve as it can leak oil.
    GForee likes this.
  17. GForee
    GForee New Member
    Awesome!! Thank you so much!! I hadn't gotten around to a search for the code on here yet... I just had it checked a few hours ago on my way to work. This definitely gives me a place to start!
  18. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    There also have been problems with spark arcing through the plug boot. I would remove the #1 coil/boot assy and closely inspect it for signs of carbon tracking. (arcing through the boot to the valve cover) While you are at it, it would be a good time to replace the spark plugs with OEM if it has not already been done.
  19. GForee
    GForee New Member
    Took it in to a dealership (not where i bought it. That was a used car lot) and they couldn't find a problem, even though they got the shaking too! So injector cleaner and an oil change for now and see if its just junk in the gas lines... Upside is they only charged me for the oil change AND I got a wash and vacuum!! :) awesome service!!
  20. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    So i too have this shaking during accelerating but only >40mph; it ends while coasting on cruise or when my foot comes off the gas. Vibrations seem to go sideways & possibly emanating from right front engine or tire. Shakes are consistent over 40mph while going straight on mainly flat roads or uphill. Haven't noticed it going down hill. I just noticed it while on a road trip cross country loop northbound to Zion national park at 115,000 engine miles, originating from VA going on 3000:8000 total miles. I've been using the cheap gas & after a few bottles of carberator cleaner. Ive had the 2005 Prius since Jul 2015 & havent noticed shakes until now.
    I will try new spark plugs & full tune up. Thanks.
