Share your Torque layouts here!
Discussion in 'Prius OBDII Third-Party Apps' started by RavenTBK, Dec 29, 2014.
  1. RavenTBK
    RavenTBK Junior Member
    Apalachicola National Forest, FL
    Anybody wish to export and share their gauge layouts? I'm still halfway through building my own, and am not satisfied with the outcome. I'd be interested in seeing what the community has done with regards to easy monitoring of Pirii. As I am sure there are some other folks out there that are "just curious" and want to see what others see.
    To export from Torque:
    Long press on a realtime data page, select "Layout Settings"
    Then, select "Export"
    Type in a file name for your gauge export, and hit OK.
    Locate your saved dashboard in your ".torque/dashboards/" folder.
    Make it a zip, and attach it to the thread. :D
    To import back into Torque:
    Save your zip file from the thread on your device.
    Unzip its contents into your ".torque/dashboards/" folder.
    Inside the Torque app, go to realtime data and long press - select "Layout Settings".
    Select "Import"
    Select the file name you wish to import and hit OK.
    Enjoy your new view.
    PS, it should be noted that gauges that reference unknown PIDs will not function..so if you get a layout with non-working gauges, be sure to download the proper generation Prius PID file from the other thread.
    SFO likes this.
  2. johnjohnchu
    johnjohnchu Active Member
    212
    105
    Can not find the saved layout in .torque/dashboards/ folder.
  3. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    I'm still working on this one. Its got a 2nd page, but main one with the dials is what I'm experimenting with. 2010 Gen III Prius with the custom pics loaded. Needed higher contrast with sun hitting the nexus 7 screen. I don't know what gauges are ideal, but my purpose is high mpg -- so timing advance, rpm is interesting to me. I'd like to learn how to make a dial to measure HP and which motor is providing the power to wheels and charging status. Just not there yet.
    SFO likes this.
  4. Rhinoruns
    Rhinoruns Member
    61
    38
    Madison, WI
    Should add ... The ".torque" folder is hidden (at least on my tablet) and had to enable "see hidden files" for the file manager app to locate it.
    SFO likes this.
  5. PeterPrius2007
    PeterPrius2007 Junior Member
    47
    Kitchener
    This is an old thread, but does anyone have a good layout to analyze their HV battery?
    I'm trying to figure out how good (or bad) my HV battery is using Torque Pro. Not sure what to look at yet.
    Danny13pruisc3 and SFO like this.
  6. 14.4v
    14.4v New Member
    17
    24
    Denver
    2003 Prius
    I
    what adapter do you use? i only get the main ecu.
  7. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
    Not yet, but I'm going to work on it this weekend (and I'm following this thread with interest)! I just switched to an Android phone (from iOS, where I was using the EngineLink app), so I'm still figuring out Torque Pro.
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  9. gamma742
    gamma742 Member
    178
    73
    Luxury
    Screenshot_2017-12-20-12-11-41.png Screenshot_2017-12-28-13-28-31.png Screenshot_2017-12-28-16-02-36.png
    RickyV12 and SFO like this.
  10. marlinsmobile
    106
    131
    Here's mine - I keep it pretty basic, just the values that I need to be able to monitor while driving.
    Day-to-day, I mainly keep an eye on the coolant and battery temps, plus the HV battery current and SoC. If I'm stuck in stop-and-go traffic, I use the gauge to manage SoC, because nothing makes me more annoyed than sitting still with the engine running!
    I log many other PIDs (such as voltage and resistance of the individual battery blocks, fan motor voltage, etc.) I monitor those values by graphing the logs later, since I can't really interpret the values while on the road.
    I've recently switched to Torque from EngineLink (I used to have an iphone). It's interesting that Torque lets you set the list of PIDs for logging separately from those displayed on the layout; in EngineLink, only PIDs displayed on the dashboard layout are logged.
    SFO likes this.
  11. Sezy
    Sezy Active Member
    439
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Could use some tweaking but this is what I use.
    SFO likes this.
  12. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    Marlin - when I am sitting still in my 2007 Prius the engine shuts down. Do the newer ones actually continue to run? Bummer if they do. That is what I can enjoy most about being stuck in traffic - not wasting gas.
  13. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    BTW - something changed in Torque. To get to export/import on mine, I hit Realtime Information then the setting gear at the bottom of any screen. Layout Settings is there.
  14. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    I found an error in PRIUS PIDs - The entry for {PRIUS}InternalResistance)08 is actually IR6 and there is no IR8 entry. At least I didn't find one with the equation 0.001*W, though I didn't search all PIDs.
  15. gamma742
    gamma742 Member
    178
    73
    Luxury
    Danny13pruisc3, Sezy and SFO like this.
  16. azjerry
    azjerry Junior Member
    29
    Phoenix
    Anyone have a layout specifically for a 2018 Camry LE? Or a set of PIDs?
    #16 azjerry, Aug 30, 2018
  17. Luciano Martins
    Luciano Martins Junior Member
    Porto, Portugal
    It's my first Dashboard for check Battery.
  18. gamma742
    gamma742 Member
    178
    73
    Luxury
    I have what you need.. are you familiar with Custom PIDs?
  19. Ragnorok
    Ragnorok New Member
    New Hamshire
    Howdy all. Prius Noob here, sort of. Got an used 2005 last November as an experiment in mileage that has so far been a smashing success. Get over 60 commuting to work. \o/
    It seemed like my batter wasn't working up to snuff (still had the original) so I found a place to install one on the cheap. I saw they used an app to read the HV codes and that got me thinking I could do the same. Today I searche, and found this thread, which *appears* to be listing battery data in Torque Pro. As fate would have it, I bought Torque Pro about ten years ago and it's my go-to tool for anything OBD. Used it on a whole pile of vehicles, including Wembley (the prius). But I don't see battery data.
    This makes me think my OBD adapter, which was cheap when I got it all those years ago, doesn't expose all the data it could expose. I did look at the OBD/Tool post and it seems most there have used actual scan tools, and the one cheap ELM adapter has trouble getting HV data, too. (grin)
    So I'd like to ask here, on this Torque-specific thread, what OBD adapter works well for getting HV / battery data like I see in some of the posts above. When I get it working I'll post my settings, just to be keeping with the thread. (wink)
    Thanks for your time...
  20. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
