shark fin antenna cover swap
Discussion in 'Gen 5 Prius Accessories and Modifications' started by wrtboy168, Feb 3, 2024.
  1. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    i'm wondering if one can safely remove the shark fin antenna cover without having to lower the rear headliner. can the antenna cover be removed with some pry tool? if it's not too much work i'm thinking about swapping the cover to a supersonic red one.
    MichaelN77 likes this.
  2. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    You can cut a hole in the headliner right by where the shark fin antenna cover is. After you cut a hole in the headliner, you can now remove the bolt or bolts that hold the shark fin to the roof of the car.
    You will also need string and heat to cut the waterproof seal between the antenna and the body of the car above.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Isn't the shark fin antenna an integral piece of the whole back section of the roof on the Gen 5 Prius?
  4. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    the gen 5 prius parts diagram shows the antenna cover is a separate piece.
    e.g. 8607712030A2 is part number for the antenna cover in windchill pearl.
  5. Harters
    335
    427
    UK
    Excel
    #5 Harters, Feb 7, 2024
    wrtboy168 likes this.
  6. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Toyota diagrams often show the older model if not much has changed. I believe the shark fin is a reused design. And KISS is being used even in the diagram.
    I have an aftermarket shark fin. You have to unbolt it from beneath after cutting* or removing* the headliner. The cover on the sharkfin above is glued to the roof of the Prius in order to create a water tight seal. In order to remove it you will need some string to cut that seal.
    vvillovv likes this.
  7. Hammersmith
    Hammersmith Senior Member
    2,468
    2,524
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The glass roof and solar roof have shark fins molded into a larger piece of plastic that spans the width of the main roof. The fins themselves are not removable. The LE/SE and the XLE/XSE w/o the fixed glass roof have shark fins that are removable.
  8. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Easiest solution would be a wrap for the fin.
  9. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    i was just thinking perhaps someone had already done an oem antenna cover swap and would have some insights.
  10. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    A swap appears to require cutting into or removing the head liner. Wrapping something that small seems a fairly straightforward DIY. There are a lot of tutorials on youtube.
  11. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    i visited the dealership today for an oil change and i asked the service adviser if he can help me find out how hard it would take to do a shark fin antenna cover swap if it's possible without having to remove pillars and lowering the rear headboard. he wasn't sure so he went to the shop floor and asked one of the master technicians. he found out there is no need to lower the rear headboard and it's a simple pop off and pop on for the antenna cover. the dealership's minimum labor is half hour hence a $95 quote for an antenna cover swap. :unsure:
    i figured there must be a trick to it like using a plastic pry tool on a certain location of the fin so it can be safely popped off. i've searched yt and most are replacing the entire antenna assembly which requires lowering headliner, disconnecting harness, bolt, etc.
  12. Hammersmith
    2,468
    2,524
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The base of the antenna is bolted to the roof, but the cover just clicks onto the base. But it's not meant to be removed without being able to access the tabs from below. I don't know how much of a risk there'd be by forcing it from the top.
    My first choice of advice would be to buy a spare cover. That way you could wrap it at your leisure and, if a few tabs broke off the old cover during removal, it wouldn't be a big deal. But it appears Toyota doesn't sell the cover separately. If you want an OEM one, you have to buy the cover and base as a unit(86300-47230 - $85.28 at Lewis).
    BIG EDIT HERE: I'm not 100% positive, but I think you could just order a replacement cover in the proper color. I believe the correct one for Supersonic Red is 86077-12030-D2. $36.19 at Lewis Toyota*. Toyota's parts website claims the 86077-12030 antenna covers fit the 2023-24 Priuses, but I would probably try to confirm that before you order.
    *as always, order some wiper inserts, oil, or filters to get the order to $75 for free shipping
    Antenna Cover - Exterior Body Part
    I'll attach the applicable repair manual instructions below.
    #12 Hammersmith, Feb 10, 2024
    MichaelN77, Lantaral and wrtboy168 like this.
  13. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    hmm... page 6 of the prius antenna removal pdf shows a retaining tab at the rear and looks like three tabs on each side. i'm wondering if the master technician was thinking about prying the cover using those tabs along the side and rear. for certain one shouldn't try prying from the front.
    interesting and thanks @Hammersmith for the antenna removal instruction. :)
  14. Hammersmith
    2,468
    2,524
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you didn't see the edit to my previous post, you might be able to buy an OEM cover in the color you want for about $40. That might also give you a bit of a safety margin if you accidentally break a couple clips on the old one as you pry it off.
  15. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Or just cut it off with a dremel, then install the new one.
  16. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    i was thinking of the same thing. :sneaky:
    Lantaral likes this.
  17. B2P
    B2P New Member
    Atlanta, GA
    2023 Prius
    I removed mine when the roof was wrapped, I did not drop the whole headliner just the rear and squeezed my hand into their to undo the mounting bolt with a racket. I feel like it was easier then removing the whole headliner. I never replaced the shark fin as i do not listen to the radio.
