Shark Fin
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mr estrada, Apr 17, 2013.
  1. mr estrada
    mr estrada Junior Member
    43
    i'm planning on adding the Shark Fin Antenna but i want to know if any has experience with it, installation, reception...you name it.
    GO.
    thanks.
  2. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    There are several threads that will come up with a search on these forums. Hint: Use search terms like Prius Shark Fin Antenna ;)
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    Had mine for over a year. No issues. Reception is as good as the "duckie."
  4. mr estrada
    43
    hi Rude person's where did you purchase your Shark Fin Antenna?
  5. mr estrada
    43
    new guy over here, what do you mean by "duckie"?
  6. Mike500
    2,593
    767
    The short flexible antenna has long been known as a "rubber duckie." Maybe I'm dated, but that originated in the 1970's with the CB lingo and that craze.
  7. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    The Prius Chat store has a Shark Fin that is quite nice. If you go here and look through you can see different mods people have done: What did you do to ur Prius today???? | Page 77 | PriusChat
    I linked directly to my post showing the shark fin. It's super easy to install. Reception is good and It stands out among all the other BP Pri I've been seeing around lately. Where are they all coming from!!!!!????
  8. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    50
    Tampa, FL
    I have the prius chat one. blizzard paint matches exactly installation straight forward and looks great no notice in loss of reception but i am on XM 90% of the time.
    Blu-ray likes this.
  9. ockevin
    ockevin Active Member
    493
    148
    Orange County
    I got mine from Beat Sonic USA and its great.
  10. mr estrada
    43
    Is it safe to drive through a car wash with it installed?
  11. xliderider
    8,140
    3,278
    Honolulu, HI
    Yes, it is.
  12. ockevin
    493
    148
    Orange County
    No problem after one year.
  13. Lopez92311
    Lopez92311 Junior Member
    35
    High Desert SoCal
    How hard is it to install
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Easy, as long as you have good hand-eye coordination.
  15. Mike500
    2,593
    767
    Getting the alignment right is the toughest part. I used masking tape to mark the boundaries.
    Blu-ray likes this.
  16. Blu-ray
    471
    198
    TampaBay, FL
    I have only taken my car through the touchless and the carwash that doesn't have brushes but those fabric strips. So far so good.
  17. Blu-ray
    471
    198
    TampaBay, FL
    I used the blue tape to do it. I lined it up, taped all the way around then wiped with alcohol, then straight dawn, wiped clean, more alcohol, and more alcohol, wiped again, alcohol again, wiped dry and then applied. LOL I was making damn sure there was no wax there.
  18. Lopez92311
    35
    High Desert SoCal
    Has anyone used the one from beatsonicusa? It's much more expensive but heard its bigger and gives better reception
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    A few members have it. Yes, the consensus is it's bigger and generally gives better reception. You'll need to decide whether you want a bigger or smaller shark fin for the look you're going after. The shapes are also slightly different.
  20. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    + 1 for beat sonic
    mr estrada likes this.
