Sharkfin (radio reception) for 2010 or newer models?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by riva, Feb 21, 2011.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    727
    Wow. I've never heard anybody complain about the visual aesthetics of Visual Garage's shark fin. Black colored tape isn't good enough for you? The 3M automotive tape is 1mm thick. I don't know what you expected. Again, nobody else is complaining. As for the tape protruding, you may have received a bad batch. Mine is completely flush with the base of the antenna.
    Again I think your expectations are all wrong. You can't expect a Lexus or BMW quality antenna from an aftermarket product. Remember, the aftermarket add-on has to be large enough to fit above the base of the existing antenna, so it'll never have the low-profile design of a Lexus antenna. However, for what it is, the VG antenna looks much better than stock and I've been complimented on it many times. Several other people have not even noticed it, and that's probably the best compliment.
    If you are so picky about aesthetics I doubt you'll be very satisfied with Beat Sonic's as well. In fact, Beat Sonic's shark fin is even bigger and more conspicuous than VGs. But I hope it all works out for you.
  2. danvee
    danvee Blizzard Brigadier
    326
    53
    38
    New Jersey
  3. macmaster05
    4,050
    727
    ^ The problem with Beat Sonic is that it looks less OEM than Visual Garage. The base of the Beat Sonic is huge. A picture tells a thousand words: I tried to be as to scale as possible.
  4. riva
    riva New Member
    47
    Hi macmaster05 - Glad the VG one is working out for you. No argument from me on your comments. I am picky... and you are probably correct in that I probably wouldn't be pleased with the Beat Sonic either. Anyway, guess I'll take this as an $81 lesson learned....
    PS: I did mention in my prior post that the Beat Sonic was larger.
  5. macmaster05
    4,050
    727
    :) So what are you doing? Sticking to stock?
  6. riva
    riva New Member
    47
  7. macmaster05
    4,050
    727
    Oooo I love that Prius.
    I think you'll be very happy with the Lexus fin. It'll be more pricey but it is the real deal.
    Keep us updated! :)
  8. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Riva:
    I'm very interested. Please keep us posted.
  9. practica
    practica Junior Member
    43
    Raleigh, NC
    Questions to me are:
    Does it interfere with the satellite antenna in the existing base covered over?
    Does removing 3M tape rip off the paint? (there's something at 3M seemed to say has to be ground off with a power tool, i.e. won't even lift off , desired for attaching trim reliably -- not very clear; that tape made for side moldings etc., but lots of different 3M technical products).
    How does attachment hold up to automatic car wash brushes? (at least the existing antenna is removable). Hard for "easily reversible" and reliable here to be consistent, would seem to require a choice.
  10. Joe166
    Joe166 New Member
    720
    96
    South Florida
    1) No. It is "transparent" and will not interfere with the satellite reception. At least it didn't on mine.
    2) Do you mean if you don't like it and want to take it off? No, I had to remove mine because I stupidly put it on crooked. I called the manufacturer and they sent me a new double sided tape gasket and the original tape came off easily with some monofilament line to start with and a plastic putty knife for most of it. I tried to mostly remove the tape from the sharkfin as I figured if I scratched it it was no big deal, but it came off very easily. Residue was just foam and sticky stuff that came off easily with alcohol. In fact, you can probably make the removal much easier by putting some alcohol on the outside of it. I didn't do that.
    Edit: I forgot to answer about the automatic car wash. I have no idea because I have never used an automatic car wash. The only thing I can say is that I had mine on for more than 20,000 miles, in driving rainstorms, and one hurricane when it was parked outside (I felt it more prudent to garage my convertible) and it was fine.
