She’s home - charger hooked up
Discussion in 'Prime Plug-in Charging' started by DBLXX, Mar 5, 2020.
  1. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    I decided to take the advice and direction of people smarter than me here on this forum.
    I’m sticking with the 110 outlet charging. Took Robs advice and got a fat extension cord from Lowes. The cord after an hour of charging isn’t even warm so I’m assuming it’s ok.
    Not sure if I needed the GFI but I got it anyway. The plug you see is the one on the ceiling for the garage door opener.
    Photos of my set up >
  2. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    It's a 20 foot cord and it's stretched out about 8 feet.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Yahoo!!! Just a caution. I see other stuff plugged in to that outlet. That's liable to lead to a tripped circuit breaker since the car will pull a pretty heavy load by itself. If it's really small stuff, you're OK.
    Tips and Salamander_King like this.
  4. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Thanks for looking out Jerry. It's 2 florescent light strips and the garage door opener. I ran all 3 at once and nothing tripped but my master plan was to never be charging the car while using those shop lights or operating the door opener.
    Question for those in the know. I bought the GFI you see in the photo...is that an extra level of precaution or is it completely useless in that spot?
    Thanks!
    jerrymildred likes this.
  5. hill
    9,026
    Typically an evse, whether 120 or 240 V will have their own GFI built in, which can cause one GFI or the other to trip - plus it becomes more likely to gfi trip, the longer the extension cord is. That's because you create more resistance, and that's what the GFI picks up - ie; power going in versus how much is going back on the return leg. You only have to drop a few ohms in order to GFI trip.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I maybe wrong, but I thought all garage outlets must be GFCI-protected by code. Unless your garage is very old, it should be already GFCI protected either at outlet or at the panel.
    Congratulations on your first charge! BTW, you should update your profile to 2020 PRIME so we know what car you drive.;)
    #6 Salamander_King, Mar 5, 2020
  7. bisco
    52,823
    Looking good!(y)
  8. Mendel Leisk
    42,324
    How fat?
    I'm idly curious: for a new Tesla in the family I grabbed a 12 gauge, 25 foot, 15 amp rated cord. It seems to be functioning, likely woefully under performing, but that's the best I can do.
    Said family member, when I asked about the pending charging situation, replied: "it's just like an iPhone or some Christmas lights".
    That's what I have to work with...
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    Not knowing if that outlet is already protected, I'd say if it's working, go ahead and keep using it. If it isn't protected, the gfi will protect you as you plug & unplug the EVSE. The gfi that's in the EVSE brick is protecting everything "downstream" of it but it doesn't know what's happening "upstream." If you check and find that the outlet already has gfi protection, then the one you have pictured would not be needed.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Congrats on your new Prime. (y)
    My only concern is your 4 way splitter box, they typically are the problem point when pulling bigger amperage. If you can plug your yellow cord & yellow GFCI into a solo 120v outlet directly, that would be preferred; even if it's still on the same circuit.
    Rob43
  11. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    I just pulled the plate off the outlet and plugged that 6 way into the 2 way. It used both outlets...
    I definitely could remove the 6 way and plug the charger in one and then split the single 3 ways for the door opener and 2 lights.
    Would that be better? If so, a real quick fix up.
  12. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    That would be slightly preferred...
    Rob43
    PS, save your receipts on both Lowes purchases, 3 weeks from now you might decide that faster charging is the ticket, especially if you still can get a great deal on your 240v install.
  13. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Today he backed off that "great deal" when he realized my panel is IN my house and not IN my garage. It's now $400. :(
    I will change the set up tonight based on your recommendation.
    THANK YOU !!!!!!
  14. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Any outlet that could be exposed to liquids should be protected by a GFCI. Whether everyone actually complies with it is another story.
  15. jerrymildred
    11,517
    14,167
    Tampa, FL
    Bummer. Running the circuit from inside the house is a lot more work than if everything is in the garage. Actually, $400 isn't bad for what I'm imagining as an industrial electrician who really doesn't like residential work. ;)
  16. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    That's not how GFCIs work. They only look for leakage current, the difference between current going in and going out. No matter how much resistance is in series, the leakage current is zero if there is no other path for current.
    It can be helpful to have multiple layers of GFCI protection, since sometimes they fail with age (that's why you're supposed to test them monthly, but no one ever does. Some newer ones claim to be self-testing, but I don't understand how that works). The EVSE has its own GFCI, but if the end of the extension cord is sitting on the floor in a puddle, the EVSE can't do anything about that.
    If the garage outlet is properly GFCI protected, a stand-alone GFCI is not necessary. Each plug connection adds some resistance, which creates heat and possibly overheat if it's a bad connection. Fewer connections are better which is why Toyota doesn't want people using extension cords (among other reasons). I think an extension cord is fine if you're smart about it, but might as well eliminate any unnecessary connections.
    Look for a GFCI test button either on another outlet in the garage or on the garage circuit in the main panel. Test it, and if it shuts off power to the outlet you want to use, maybe return the standalone GFCI.
  17. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    The outlet doesn't have a GFI button on it. The outlet is in the ceiling specifically meant for the garage door opener. The entire garage has 1 other outlet in it...and it has a GFI on the face plate. (the little test button)
    That's why I bought the big yellow one. Better to be safe than sorry.
  18. Salamander_King
    11,024
    8,978
    New England
    On a same circuit, not all outlets need to be GFCI. If the one with GFCI switch is on the same circuit as the ceiling one and is closer to the panel, then your ceiling outlet is also properly GFCI protected. You can check it by tripping GFCI on the other outlet and see if the ceiling outlet is cut off.
    dig4dirt likes this.
  19. Tideland Prius
    16,678
    Could be worse. A colleague who doesn't have an EV who heard about this "trick" where you can combine two 110V outlets to get a 220V outlet and then plug your EVSE into that but you're still limited to 15A... the idea I guess was to get a higher voltage but not necessarily higher amperage.
    #19 Tideland Prius, Mar 6, 2020
    jerrymildred and Mendel Leisk like this.
  20. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    I thought about that, until I realized if you unplug one of the two 120V plugs it will have 120V on the exposed prongs. There is a box someone sells with relays that supposedly makes it safe, but for the cost might as well just have an electrician put in the right outlet.
