She's dead, Jim!
Discussion in 'Gen 2 Prius Technical Discussion' started by miwaku, Oct 9, 2006.
  1. miwaku
    miwaku New Member
    70
    Got into "Smudge" yesterday morning, started her up, and got the Master Warning triangle, the Check Display warning (meaning "look at the MFD"), and my fuel gauge started flashing, first one bar for 6-7 seconds, then all ten (I'd just filled up).
    She seemed to work just fine when moving her back & forth a little to see if there was a transaxle problem, but no matter how many restarts, same behavior. Checked all the fuses, etc, no luck. At one point when putting her in D I got an error along the lines of "Place engine in Park; battery will not charge in Neutral" or some such, even though the transmission display indicated I was in D. This error didn't come up every time, though.
    Took her around the block and the battery kept draining to one bar, with no ICE kicking in! Finally, she just rolled to a stop. Battery stayed at one bar, ICE wouldn't recharge or drive the car. ABS and Road Condition lights came on, as well, and the Ready light flashed a couple of times, then went out!
    I pushed her to the curb and just this morning called Toyota Service (this always happens on a Sunday).
    They're coming to take her in, and I'll let everyone know the Diagnosis. Here's a pic (sorry for the night view):
  2. ribbs
    ribbs New Member
    47
    Malibu, Ca.
    I put my money on a fuel supply problem of some sort - fuel pump, maybe.
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Good that you have a picture and a good documentation of the situation. I remember when I had an issue with Priapus, I made sure to document every detail, every step, and every response. In the end, I didn't need all that detail, but I'd rather have it and not need it than need it and not have it.
    I'm not technical or mechanical in those matters so I won't make any speculation as to what the problem might be. Be sure to keep us posted though.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    this should be interesting, as it could be one of many things. Do keep us posted on the cause and if you can get the codes that caused it. tia
  5. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I once had the "Place engine in Park; battery will not charge in Neutral" sign, and it happened to be that the driver's door was not properly closed!
  6. AAWADKE
    AAWADKE New Member
    71
    <div class='quotetop'>QUOTE(Michgal007 @ Oct 9 2006, 10:32 AM) [snapback]330031[/snapback]</div>
    I had the same message 3 days back .....even in my case driver door was not properly closed...
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Get the DTC when they scan the car!
  8. miwaku
    miwaku New Member
    70
    Ok, the Dx is apparently that the #10 wire coming from the junction box to the ICE's ECU was loose. Because of this, the ICE would not come on, and the battery slowly ran down.
    Took them a few hours to run it down, but it seems to be ok now.
    Yes, the door WAS open when I got that error. Good catch!
    Thanks, everyone!
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Glad it was such a simple solution and such minor problem. I'm sure it was nerve wracking waiting for the fix.
  10. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That's just one injector down, that shouldn't have caused the
    engine to not run at all... just like crap, throwing "misfire # 1"
    and "too lean" codes.
    What were your codes??
    Where exactly was the wire loose, and are we actually talking about
    the one labeled "#1O" [i think that's "oh", not "zero"] or something
    else?
    _H*
