Shift Interlock Solenoid
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by loklok1, May 23, 2026.
Tags:
  1. loklok1
    loklok1 Junior Member
    47
    My c recently keeps getting stuck in Park and I cannot shift to Drive unless I manually press the shift lock release. I've tried all of the suggestions the internet has to offer and none of it is the solution. I'm down to the last suggestion which is the possibility of the shift interlock solenoid failure. My question is has anyone experienced similar issue and had had to change this thing? What does the part look like? I've taken the shifter trim/console and trying to id this thing. TIA for any info or help on this.
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    What's history of the shifter in terms of how the car has been cared for? I know people who never clean up a messy car can do all kinds of stupid damage they're oblivious to. One time during Covid we spent days helping someone with a standard Prius shifter malfunction that's much different from Prius C and out of nowhere they admitted they've been hanging all their masks from the shifter to such an extreme amount that it was the source of the failure.
  3. loklok1
    47
    I suspecting it just failed due to age. There's no liquid spilled on it. I've checked the 12V battery and fuse which all tested out fine. When I stop on the brake I can't shift out of Park until I manually press the shift lock release button. I've check AI and it seems to think the shift interlock solenoid could be an issue so I'm down this rabbit hole now.
  4. PriusCamper
    13,468
    5,438
    Your AI didn't work 'because of lack of more specific terms and word 'solenoid'
    Run it again with these keywords: parking lock actuator pawl
  5. PriusCamper
    13,468
    5,438
    But more to the point first step in stuff like this is taking apart and cleaning and inspecting as much as possible.
  6. ChapmanF
    19,041
    Because this is a thread about a Prius c, I would not be at all surprised if the OP really does mean the shift interlock solenoid, and not the parking lock actuator pawl.
  7. PriusCamper
    13,468
    5,438
    Can you explain? Are you saying Prius C has a different Park system than regular Prius?
  8. ChapmanF
    19,041
    The c has an old-school shift lever that goes kerchunk between the different shift positions.
    It seems most similar to the gen 1 in that way. Gen 1 moved the transmission parking pawl with a Bowden cable from the mechanical lever. The mechanical lever was prevented from moving out of P by a solenoid, unless your foot was on the brake. In dire straits, if the interlock circuit or solenoid wasn't working, you could poke through a hole at a mechanical lock release so you could shift out of P.
    I don't know for sure if the c is like the gen 1 in all those details, but the OP mentioned several of them, so it sounds pretty similar.
    PriusCamper likes this.
  9. PriusCamper
    13,468
    5,438
    Prius C are strange... Ones I worked on felt like they used way less parts and way less space, yet it still drives like a Prius.
