Shift into park while moving, any damage?
Discussion in 'Gen 4 Prius Main Forum' started by littlebird002, Nov 5, 2017.
  1. littlebird002
    littlebird002 Junior Member
    37
    CA
    I accidentally shifted car into park while moving at a slow speed, under 5-10mph. I heard sound like hit the wall and then immediately stepped on the brake. I estimate I traveled less than 6 ft after shifting into park. I did not have any trouble driving or stopping the car afterward.
    I am wondering if I caused any damage to my car? Do I need to bring my car to dealer?
    Thanks a lot.
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I don't think you will have done any major damage, because there is a safety override preventing the parking lock engaging at an unsafe speed. You may want to try the P Button on a slope soon to see if it still works normally, but according to @Prodigyplace recently, there is a pawl which engages to prevent a rotating part from spinning in the drive line somewhere. You might have guessed, I'm no technical genius. ;)
    fuzzy1 and jerrymildred like this.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Some cars use a pin in the transmission to lock the drive, but the Prius uses a "hypoid gear" to do so. It's much stronger. It can be replaced without full disassemble of the HSD as it's "external". If "P" still stops the car from rolling you did little to no damage. Many have done this, don't worry about it. It's rare to damage it.
  4. littlebird002
    37
    CA
    Sure.Thank you very much.
    RCO likes this.
  5. littlebird002
    37
    CA
    I have tried "P", it still stops the car from rolling :)
    Very appreciate your detailed information. Have a wonderful day.
    pilotgrrl, Raytheeagle and RCO like this.
  6. ChapmanF
    19,047
    The Prius transaxle still uses an internal pawl to lock the drive. The cycloid gear mechanism referred to here is just the torque multiplier for the little electric motor that moves the pawl into and out of position (instead of using a big mechanical shift lever pulling a cable, as Gen 1 did). If something goes wrong with the motor/gear, that can be replaced (it's called the Shift Control Actuator), but if something breaks the pawl, that's still a transaxle teardown.
    But you're not very likely to break the pawl, because even if you do press Park when your speed is too high, the computer will just beep at you and shift to Neutral instead.
    A hypoid gear is a different sort of animal, often seen in rear-wheel-drive axles.
    -Chap
    pilotgrrl and RCO like this.
  7. littlebird002
    37
    CA
    Sure. Have a lot things to learn.
    I am thinking whether I should take couple Automotive classes during my spare time.
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You're welcome. You too, have a good one. :)
    pilotgrrl and Raytheeagle like this.
