Shifter, "D" should be forward motion and "R" should be backward motion
Discussion in 'Gen 3 Prius Main Forum' started by Goodair, Aug 30, 2010.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    This isn't the first time this has been spoken about and I am certain it will not be the last.
    That being said I simply don't see the big deal. You get used to it and never think about it again... I guess if it is dwelled upon one will never get used to it. And I am not saying this applies to the OP but people who adamantly curse Toyota for the way it is, and trust me, they are out there.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    I'm with you on this one. My Jeep had a three speed floor shift. My Honda CRX had a five with an entirely different pattern. I went back and forth without issue.
    Gnome used to have the window buttons on the right side, now they are on the left. It took about three days to get used to it.
    Standards are nice, but some flexibility is needed if one is to get through life.
    Tom
  3. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    I wasn't around when they tried the experiment, or somehow missed it. Those plymouth buttons from the 50s just weren't right. IMHO a rocker switch foward top down (Forward), reverse bottom down (Reverse), neutral is neutral, park is pressed to release the toggle out. The park button, start button, and then joy stick seems like a poor interface. So instead of park we hit the start switch to turn it off. Its not a huge deal, but ergonomically I give it a 2 on a scale of 1-10.
    But they did reinvent the shifter with 2 buttons (Park and Start) and a joy stick. I'm surprised other keyboards are not available now that alternatives are cheap to build. We no longer need to design them so that mechanical keys won't jam.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Push-button shifters came out in 1956 on some Chrysler products and the last of them were off the market by 1965. I didn't realize they lasted that long. A big advantage to a lever or joystick is you can just grab it with your front paw and move it in the necessary direction without looking. Push buttons require much finer motor control.
    You already have a other keyboard options. They are built into Windows and Mac OS and are just a software option selection away.
    The most common alternate keyboard arrangement, Dvorak is available in hardware if you insist on your key markings being the same as the letters you get when you type.:D
  5. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    There is probably not one automobile from a major car manufacturer in the world that designs their floor-mounted automatic transmission shifter with 'D' toward the front and 'P' or 'R' to the back.
    OK, that may be intuitive but Toyota MUST maintain industry standards. Imagine the lawsuits.... new drivers. rental vehicles. stupid people. Unintended Drive or Reverse.
    Also, if Toyota would have designed pushbutton transmission selection for the Prius, sure may have impacted sales and unleashed critics. "golf cart"?
    So perhaps we can stop slamming Toyota.
    Next thing you know some folks will complain about having the steering wheel on the left side. wait... I take that back.
  6. pricarl
    pricarl Junior Member
    I agree 100% the shifter D and R should be reversed. This is a different car, and designed with foward thinking right? Well it makes sense push foward to go foward and push back to go back. I got caught a couple times parked doing opposite. Now I make sure I look twice in making sure I shifted correctly.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    For those that do not like the D and R positions, this is drive-by-wire technology, so try swapping the wires :D
  8. Goodair
    Goodair New Member
    48
    SGV
    Finally, I found an outside of the box thinker, the Prius is a forward thinking in every aspect, like you said, forward should be drive and back should be reverse. Its a no brainer!
  9. Goodair
    Goodair New Member
    48
    SGV
    That is right,,,simple wire MOD and some stickers would do it.
  10. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    You cant really call push forward for forward, pull backward for backward, thinking outside the box.
    You dont see how it would cause problems being opposite of every other car in production?
    A change and a good idea do not go hand in hand.
    Electrochromic glass all around sounds like a great way to build in automatic sunshades... until it malfunctions while your driving:eek:
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  12. austingreen
    13,714
    4,232
    Austin, TX, USA
    OK, I read it to see if there was something that I could learn. There was, in automatics without park (prius) the gear position must be displayed to the driver whenever the car can move (ready state), and neutral must be between Forward and Reverse.
    Since it is not a column shifter it says nothing about relative position of Forward and reverse other than neutral must be inbetween. Even if you were to take the convention stated that neutral to forward is clockwise, Left (9:00)is Neutral, down(6:00) is Forward, that is counter clockwise. Luckily or unluckily since it is not a column shifter this part of the reg can be ignored. Since the shifter does not stay in position its not really counter clockwise.
    Not a big deal, but the regulation does not say to design it backwards, it just allows toyota to do it the way they did.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I wondered about the self start a couple of weeks ago, so I checked. Toyota applied for and received a special dispensation to cover the self starting feature. I lost the link to the dispensation but it has been incorporated in the latest version of CFR 49 571.102 at S3.1.3.1
    Electronic Code of Federal Regulations:
    It looks like they comply with the spirit of the reg by having a ccw movement to engage R and a cw movement to engage D as viewed from the drivers seat. Right off hand, I think all other AT cars do it that way too.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It also says thy have to put P near the R end. (If they have a P)
    So they are allowed
    P
    R
    N
    D
    or
    D
    N
    R
    P
    And frankly 99% of us are used to PRND not DNRP.
  15. austingreen
    13,714
    4,232
    Austin, TX, USA
    cool
    No its actually the oposite of the convention. R(12:00), N(9:00),D(F)(6:00). All counter clockwise. This is a new device though, no normal shifter goes back to the centered position, neutral between forward and reverse is done electronically. If you shift from one to the other while moving it will move you to neutral instead. Since it is not a column based shifter it does not need to follow the clockwise direction according to the regulation.
    Yes if P was on the shifter the convention would be on top and Reverse would be pulled back from P. This would make it feel like it followed convention. But P is not on the shifter, so the regulation and convention says nothing about where it should be. A car does not even need to have a parking gear, which is a good thing as manual transmissions don't, at least none that I've driven. A self centering joystick shifter with a button for park is a new model so it is free to set its own conventions. I would have prefered a shifter that included Park on it, but really I'm used to one I have, and its all pretty academic.
    until the next thread......
  16. Goodair
    Goodair New Member
    48
    SGV
    If status quo was used in the design of the Prius, our cars would be completely different and this forum would not exist. The Prius was designed by forward thinkers, maybe its time to change old practices.
    Just think at one point everyone thought the earth was flat. Change has to start somewhere, maybe it is time to change things around. When you push a lever forward, it should be forward, not the other way around. Its really not that revolutionary. Think about this when you jump in your Prius tomorrow. It really makes sense, especially with the layout we have, to park the car we push a button, how many 2010 cars have that feature.
  17. vday
    vday Member
    312
    Israel
    I agree
    I still sometimes make a mistake till I hear the beep:)
  18. Blizzard10
    168
    38
    Queens, NYC
    I get it, you'd like the shifter to work opposite of the way it does.
    I like it the way it is
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    "If the transmission shift lever sequence includes a park position, it shall be located at the end, adjacent to the reverse drive position."
    They are allowed not to have Park, but the spirit of this law is that if they have one, it is next to Reverse and that it be one end of the pattern.
  20. vday
    vday Member
    312
    Israel
    I very rarely press the P
    I just shot down th car and the Pri does it itself:)
