Shifting out of gear in cold weather
Discussion in 'Gen 2 Prius Main Forum' started by Daddee, Nov 14, 2014.
  1. Daddee
    Daddee New Member
    My 2005 Prius shifts into Neutral, "N", when I put it either into Drive, "D", or Reverse, "R", during Cold weather, mid 20's and below. It will only stay in "B" to drive, and I have to hold the shifter in "R" to back up or "D" to drive. After the car warms up while driving 15-20 minutes in "B", I can shift it into "D" and it will stay there. I normally start the car and let it warm up in the morning for 10-15 minutes on cold days, below 25F but still I'm only able to drive it in "B" until it's ready. I just moved to Montana after driving this car in normal Southern California driving conditions. It happened while vacationing in Montana during the winter of 2007 a few times but it didn't bother me since I wasn't living there. I reported to Toyota but they couldn't do anything since the weather wouldn't co-operate. This car is still under 70,000 miles.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Have you tried fresh ATF-WS? It is a drain and fill, no flush, no filter.
  3. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    This sounds like a problem with the electronic shift lever. I suggest taking video of the problem when it happens, and produce this as evidence to the dealer. This is not a major problem just requiring the lever in the dash to be changed "a simple job", but I agree you should not have to pay for this repair.
    The shift mechanism is electronic and any gear selection from N to D to R to B is purely an electrical state within the transmission.
    Mechanically nothing changes. In simple terms, reverse is just a change of direction of the electric motor, neutral is no electrical supply to the motor.
    John (Britprius)
    #3 Britprius, Nov 14, 2014
    GrumpyCabbie and *Goldfinger* like this.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    From what I've read, I agree with the shift lever diagnosis. I believe the rubber bezels/seals inside the shifter sufficiently harden at cold temperatures to cause unintended shifts.
  5. Daddee
    Daddee New Member
    Thank you, I have video'ed it and will bring these suggestions up with the dealership and Toyota Corporate.
  6. Britprius
    5,194
    1,918
    Please let us know the final outcome of your problem. This is helpful to future posters with similar problems, and your input on anything Prius will always be welcome along with any questions you may have.
    It would be helpful if you gave your location in your avatar.
    John (Britprius)
  7. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    It's also an easy repair if Toyota ends up stiffing you. I'd do it for $10 and the part. The only trick is learning to take the dash apart the first time.
    You definitely shouldn't have to pay a cent though. I'd also like to know how it goes with Toyota. For reference, I've never experienced anything similar; it's definitely not a normal Prius problem. Sounds like the shifter is just slightly out of spec and heating/cooling expansion/contraction throws something off the tiniest bit.
  8. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I'm curious as to why he should expect to not have to pay for this repair, as his car is no longer under warranty. It would be great if he didn't have to pay of course, I'm just looking for the reasoning.
    Unfortunately for me, I came from the world of BMW ownership where MANY things are expected to break, and very little was ever covered by dealers. Never again!
  9. Patrick Wong
    18,200
    6,493
  10. GregP507
    GregP507 Senior Member
    3,002
    481
    This is definitely not normal, and the dealer needs to help you resolve it. This shouldn't happen at all, ever. If you can't reproduce it at the dealership, take a video of it happening.
    Where I live, 25F isn't cold at all. The Prius is a car very well-suited to cold weather, and I've been through -25F weather already with no problems at all. I have no doubt that -40 will present no problems for it either.
