Shifting to "P"
Discussion in 'Gen 2 Prius Technical Discussion' started by DRogers, Nov 6, 2014.
  1. brucebee
    brucebee Junior Member
    84
    vista, ca
    my 04 going from d to p seems a little less sensitive lately, twice in last wk it didnt go in... might be driver error . i now check
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I almost never shift to P myself, as it goes to P automatically when you power down. If you spent more time in your car stationary than I do, it might be used more.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I know nearly every fault at some time has been laid at the door of the 12 volt battery, but could erratic shifting to P be caused by a low 12 volt battery. The pawl motor is fed from the 12 volt bus although this in theory is supported by the DC to DC converter.
    John (Britprius)
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    That sounds more like a faulty gear shifter. I bought a used one from autobeyours.com for ~ $65 and resolved the symptoms.
    Very easy DIY install by the way.
    When I looked at my old one after replacement I thought it might be fixed by snipping off a bit of plastic that had warped, but I was too lazy to find out for sure.
    #24 SageBrush, Nov 10, 2014
  5. Britprius
    5,194
    1,922
    Pressing P avoids the problem with the shifter so if the problem goes away using the P button it would point the guilt at the shifter if the problem still exists it points elsewhere.
    John (Britprius)
    Data Daedalus and SageBrush like this.
  6. Shaan
    Shaan Junior Member
    Austin
    2003 Prius
    Hi there - anyone faced issues listed here
    1st gen prius drives but does not park | PriusChat
    pls help
  7. bisco
    52,694
    see my response in that thread.
    Data Daedalus likes this.
