Shipping fuel regulations could cause more global warming
Discussion in 'Environmental Discussion' started by drees, Jan 19, 2010.
  1. drees
    drees Senior Member
    1,782
    247
    New Clean-Fuel Rules For Ships Could Actually Hurt the Environment | Popular Science
    Interesting. The article claims that about half of the AGW effect of CO2 and other gasses is offset by sulfate aerosols emitted by large ships. Anyone have a reference to back this up?
    Here's an image which shows off ship-tracks. Quite amazing how much cloud cover they can create.
    Bunker fuel in large ships is responsible for a huge amount of pollution and while most of it is burned miles away from shore, winds carry significant amounts of it onshore. Air pollution near ports, for example is a very significant health problem where regulators are constantly working on ways to reduce pollution levels. Since aerosol pollution doesn't last too long in the air, it shouldn't take long to see what the effects are.
    With 2009 already being one of the warmest on record and 2010 also predicted to be very warm due to the El Nino, it will be interesting to see if this has any further effect on this year's temperatures. Seems more likely we'd see the effects in 2011 and beyond as the pollution settles out of the air, though.
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    Very interesting,,,
    It might also be interesting to see if a similar image exists for intercontinental aircraft.
  3. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    Aerosols offset warming, and at first glance that's not implausible. Here are the forcings in the NASA GISS model.
    Data @ NASA GISS: Forcings in GISS Climate Model
    So, looking at that graph, it's clear that aerosols matter a lot. In fact, the most plausible explanation of post-WWII lack of warming globally was increased atmospheric aerosols, as evidenced by increased sulphate aerosols in Greenland ice over that period. Because, as you can see from the GISS forcings graph, aerosols pretty nearly offset all GHG emissions even now.
    Various clean air acts and, in the US, cap and trade for S02 emissions, have greatly reduced sulphate aerosols from stationary sources. Add low-sulphur diesel for cars, and, yeah, it's plausible that ocean transport could be a major contributor by default -- its the last source left.
    Here's one source, unknown quality, claiming that ships account for 39% of the effect of manmade sulphate aerosols.
    Institute for Atmospheric Physics - Aerosols from ocean shipping cause a significant negative climate forcing
    Here's one that's 10 years old, in the same vein, so it's not as if that's not been said before:
    http://www.nature.com/nature/journal/v400/n6746/abs/400743a0.html
    But a problem with aerosols and particulates as "solutions" to warming is that the C02 hangs around for a long time, while the aerosols wash out of the atmosphere in a couple of years (as evidenced by the impact of Pinatubo and similar volcanoes -- their primary cooling effect was from injecting S02 into the stratosphere, forming sulphate aerosols).
    Anyway, the basic point seems sound -- it would be like the impact of various Clean Air acts, all over again.
    And, when you get right down to it, one of the few relatively benign geoengineering proposals is to create a fleet of ships to aspirate seawater, so that salt will form condensation nucleii and you'll increase ocean cloud cover. Cleaning up bunker fuel would be like that proposal in reverse.
  4. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Oh wow a computer model of climate by a group that is trying to push global warming on the masses? I bet that's some accurate stuff! I wonder how much input Dr. Hansen (the psychotic alarmist) had?
  5. radioprius1
    1,355
    155
    Iceland
    Speaking of ships:
    Sensor problems with ship based CO2 flux measurements – readings too high, affected by humidity Watts Up With That?
    Sensor problems with ship based CO2 flux measurements – readings too high, affected by humidity :)
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Thank you for adding to this thread, not sure what you added but it is a post longer now. Yes I know I'm guilty of the same thing.
    Funny how much like jet trails those ship trails look. It must have been a still day for the trails to stay in place so long as to allow a ship to cross an ocean.
  7. icarus
    4,884
    976
    earth
    Does anyone have any idea of the time frame of the picture? Is it real time or is it a composite of several days? It would be interesting to know total emissions per ton/mile of ocean ships compared to other forms of transport, including rail, truck and even air.
    My intuition would be that shipping should be the most efficient in terms of fuel burned per ton mile, and ergo should be the lowest total emissions per ton mile.
    Icarus
    PS Rp1, nobody cares!
  8. drees
    drees Senior Member
    1,782
    247
    Must have been...
    It's a still frame.
    Boats are very efficient compared to air, but don't know how it compares to train.
    Since you basically only have two options (air/boat) for transport over the oceans, it's clear that boats should be used whenever possible.
