Shocks Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikednpv, Oct 27, 2012.
  1. mikednpv
    mikednpv Junior Member
    40
    16
    I'm going to replace my struts and springs on my 2005 Gen II. I'm looking to buy the parts online and do the work myself. Can anyone recommend good reliable sites to look at?
    Thank you for your help.
    Mike
  2. Patrick Wong
    18,210
    6,514
    toyotaworld.com
  3. mikednpv
    40
    16
    I'll check them out. Thanks!
    Any one else with a recommendation?
  4. Meister
    Meister Junior Member
    San Antonio, TX
  5. mikednpv
    40
    16
    Thank you :)
  6. hc167
    hc167 Member
    132
    US
    Fubar1764 and Mike Mc like this.
  7. mikednpv
    40
    16
    Thanks for the link. I'll check it out. I'm going to replace the springs since I have 198,000 miles on the car.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Killer deal HC. And to OP Mikedn its easier to hit the like button if you want to thank someone. That's why its there. its the blue word like bottom right of the post.
    mikednpv likes this.
  9. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I hope to have upgraded to a PIP or Gen3 before my struts/shocks wear out :D
  10. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    for us canadian users, is there an option? anyone tried any aftermarket units?
  11. richard schumacher
    7,676
    1,059
    United States
    How does one tell that springs have worn out? I hesitate to ask any of the friendly neighborhood rapacious dealer service advisers...
  12. Patrick Wong
    18,210
    6,514
    Find a specific reference point at each corner of the body, and measure the height of the body at those points, above the ground. If you see a big difference from left to right or if you see that the rear is sagging compared to the front (or vice versa) then you have a clue that the springs are worn. Usually this is not an issue until the odometer is well into six-digits unless the car has been abused carrying heavy loads in the hatch.
    philmcneal likes this.
  13. Chopperman83
    Chopperman83 Junior Member
    JustSuspension.com
  14. Rich12
    Rich12 Member
    176
    29
    Try tirerack.com
    Oh and you don't need to take off the wipers, wiper motors, cowl, relay box, etc. to change the fronts. All you need is:
    tommymommy likes this.
