Shopping for a Used Prius
Discussion in 'Gen 3 Prius Main Forum' started by Richy2010, Aug 6, 2015.
  1. Richy2010
    Richy2010 New Member
    Oceanside, CA
    I was doing some research online and I read that all Prius are covered for 10yr/150k or 8yr/100k depending on the state. Is this for ALL prius, regardless if its CPO or not? Or is it only for new Prius?
    Thank you guys.
  2. Patrick Wong
    18,210
    6,517
    The extended coverage relates to certain hybrid components like the traction battery, the traction battery ECU, the inverter and the hybrid vehicle ECU. The time duration depends on the component. This is a factory warranty so it applies to used Prius regardless of certified status or not (unless the car has a salvage title).
  3. Richy2010
    Oceanside, CA
    Thank you so much!
