shopping list check for package II GPS upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by Azimuth, Mar 3, 2010.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    1. To clarify, you have 6 speakers, but they are run on 4 lines (the front pair are the same wire).
    2. Standard harness should do everything
    3. Does the Pioneer come with a mic (external) - if so, a good mounting spot is on top of the steering column behind the steering wheel.
    4. Reverse camera (???) - they're cheap on Ebay, and it's a good time to do it...
  2. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    it does have a mic, and I have mine attached to the top of the steering column. It kept on moving the one piece of double backed tape, but stays in place with 2. I would rather use a better single black or clear double back tape to attach if anyone has suggestions.
    I used the boyo 420, which was around $60 on amazon. It is a little thick but works well. I think the factory type looks better. I would get a ccd camera instead of cmos. It really helps with parallel parking.
  3. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I ran the mic wire up to the factory location. I then wrap around the mic in velcro and point it to driver. So far nobody complain about the voice quality or noise. The mic wire is long enough and I have the A-pillar plastic removed to run switched 12v for V1 so it's not big deal to do it.
