Short Caused U0293
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dbasra99, Apr 18, 2022.
  1. Dbasra99
    Dbasra99 Junior Member
    32
    Parkersburg WV
    I was tightening the positive battery cable and touched the hybrid battery. There was a spark and now I have a U293 error.....any suggestion?
    I have tried disconnecting the 12V.
    The 12V battery is at 12.1V
    Thanks
    #1 Dbasra99, Apr 18, 2022
  2. ChapmanF
    18,969
    Could you give more detail? You mention the "hybrid battery" (which is the large, high voltage one under a long metal cover), but you don't mention which battery's positive cable you were tightening, or what you touched the hybrid battery with, or what part of it, or what its cover was doing off, if that was the battery you mean.
  3. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    Can you give us more details... Like specifically what part of HV battery was touched and with a metal tool? Did metal tool also touch positive terminal of 12v or positive terminal of HV battery?
  4. Dbasra99
    32
    Parkersburg WV
    I was tightening the 12V battery positive connection and touched the metal cover over the high voltage battery with my ratchet. The cover was still on the high voltage battery.
    Also, this is a plug in prius.
    I tried resetting the error with my OBD tool but it just comes right back.
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    How can you still be alive if you managed to arc the hybrid battery
  6. tankyuong
    1,555
    662
    Central MO
    Try to reset with a code reader
  7. Dbasra99
    32
    Parkersburg WV
    I tried that and it just comes right back.
  8. Dbasra99
    32
    Parkersburg WV
    The connection was made with a ratchet between the positive on the 12V battery and the metal cover of the Hybrid battery.
  9. Dbasra99
    32
    Parkersburg WV
    I did some searches but it was not clear to me about possible fuses.
  10. PriusCamper
    13,417
    5,416
    Keep trying to disconnect 12v for a while so system will reset... I've not heard of something like this frying that controller, but it's certainly having a hard time re-configuring. Also Patrick has some fuses to check and other things to try here: U0293 Lost Comm w/ Hybrid Powertrain Control Module | PriusChat
  11. ChapmanF
    18,969
    In that case, it's just that the metal cover is grounded, and you touched your ratchet to grounded metal. Much less exotic situation, doesn't matter much that the grounded metal was the traction battery cover.
    U0293 is an ECU in the car saying "hmm, I can't communicate with the power management control ECU". Commonly, with these U (communication) codes, it is also helpful to know who the "I" is in that sentence—that is, which ECU is reporting the U0293 code? Some scan tools give you that information, but others just show you whatever codes were received and not where they came from.
    U0293 can be "said" by the ECM, the steering ECU, the skid control ECU, the body ECU, the certification ECU (for smart key), the A/C ECU, or by the driving support ECU (if you have the pre-collision, DRCC, lane keeping, or parking features).
    It can even be said by the power management control ECU itself, which seems weird, but there are two or three different 'virtual' controllers running in there, so it means one of them isn't communicating with another.
    The energy of the brief short and arc might have damaged the transmit or receive electronics in one of those. Troubleshooting steps in the "CAN communication system" section of the repair manual can help pin down where the issue is.
    Couldn't hurt to look at some fuses; that'd be a lucky break.
    Toyota Service Information and Where To Find It | PriusChat
  12. Dbasra99
    32
    Parkersburg WV
    Not sure this helps but it says lost communication with Hybrid Powertrain Control Module.
    There is also a flashing light I have never seen before. It looks like a lock on a car.
    It will not start in maintenance mode.
    #12 Dbasra99, Apr 18, 2022
  13. ChapmanF
    18,969
    Right, "lost communication with Hybrid Powertrain Control Module" is what the U0293 code means. (As a U0 code, it has an SAE standardized meaning. The specific Toyota name "power management control ECU" is what SAE generically calls the hybrid powertrain control module. Two names for the same thing.)
    The thing about communication error codes is that it takes two parties to have a communication error. The code itself tells you who one of the parties is. The other party is whichever ECU in the car is giving that code. So it is helpful to use a code reader that not only tells you what code was reported, but also who reported it. As you saw in post #11, there are about eight possibilities.
    The flashing red car-with-a-lock light is one that normally flashes when the car is off—a feature conceived to alert thieves that the car has a security system and they should go steal somebody else's. Sometimes people own the car a long time before noticing it. Would you say it is blinking in a different way than it normally does?
  14. Dbasra99
    32
    Parkersburg WV
    Thanks for the info. Do you have a suggestion on the right reader that would give me both sides?
    I have about 260K miles and determined not to take to the dealer unless I have to.
    Thanks
  15. ChapmanF
    18,969
    Any scan tool that groups the codes it receives according to which ECUs in the car it received them from.
    Techstream does, of course.
    Back in March, I noticed the Car Scanner phone app also does, when I saw someone post results from it.
  16. Dbasra99
    32
    Parkersburg WV
    I ordered a dongle for the car scannner. Once I find the other side of the comunication what do you suggest?
    Thanks
  17. ChapmanF
    18,969
    The repair manual. Troubleshooting steps in the "CAN communication system" section can help pin down where the issue is. It has tables giving you the likeliest places to jump in based on which communication codes you have and which ECUs can't communicate with which others.
    It is a section with comprehensive information and details and, for diagnosing network communication issues, that's what works. We might be able to help with any puzzling bits while you work through with the manual, but it's less likely that we far away forum folks can muster the concentration (or even type fast enough) to be much help without the manual. Comm issues are just like that.
  18. A.J
    A.J Junior Member
    60
    Worldwide
    May i know how you resolved this issue?
