Short drive with no inverter coolant
Discussion in 'Gen 2 Prius Technical Discussion' started by KTMracer302, Mar 26, 2019.
  1. KTMracer302
    KTMracer302 New Member
    Denver
    Three Touring
    Long story short I have a horrible leak in my inverter. Either the inverter coolant reservoir, the inverter itself, or the bleed hose is leaking. I have to drive about 15 miles to be able to get to where all my tools are and a place to work on the car.
    Is it going to be a huge deal if I drive the car 15 miles to get this fixed?
  2. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    Why not just get a jug of (the proper) coolant, fill, and keep checking and refilling on your way?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Or get it towed there.
  4. KTMracer302
    Denver
    Three Touring
    It will be leaked out before I make it out of the parking lot. It's a LARGE leak
  5. KTMracer302
    Denver
    Three Touring
    That's my last resort. I can tow dolly it over there behind my truck if shit hits the fan.
    Just curious how hit it will actually get in 15 minutes. Take 15 minutes for my truck to get to operating temps so curious if 15 minutes would get that inverter too hot. I can't imagine it would.
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Compare the cost of a tow to an inverter replacement.
    Skibob and Raytheeagle like this.
  7. KTMracer302
    Denver
    Three Touring
    I already have an extra inverter if it dies.
    Just want to know if it can handle 15 minutes. That's all.
    AzWxGuy likes this.
  8. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    Replace the inverter.
  9. RRxing
    RRxing Senior Member
    2,562
    1,841
    NEPA
    If it doesn't destroy the inverter, let us know.
    If it destroys the inverter, let us know.
    Skibob likes this.
  10. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    If the pump fails you still have fluid in the inverter to help keep it cool. In your situation you have no fluid at all to help. My money is on you destroy the inverter. You would drive your truck 15 minutes if it had no coolant in the engine?
  11. KTMracer302
    Denver
    Three Touring
    If I was only driving the truck 15 minutes to he shop to replace the motor with a new one - probably.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    It sounds like your mind is already made up. Roll with it. Just try to minimize hard acceleration and keep a reasonable speed. If the inverter gets hot, it WILL let you know. Just pull over, pop the hood and hang out for an hour to let it cool and then continue on. After you get where you're going, fix the leak.
    The only problem I foresee is that every time you drive the car, you'll have that question in the back of your mind if it's going to leave you stranded due to an eventual inverter failure. I've seen several high power IGBT failures in some 1500 hp water cooled SIEMENS variable speed drives (some due to loss of cooling and some due to water leaks). Like a hand grenade going off in the cabinet. A prius should be nowhere near as spectacular, but if it does pop, post some photos.
    Skibob likes this.
  13. Skibob
    2,912
    1,505
    Northern California
    In my experience since driving starting in 1978, anyone who has ever driven a car with no coolant in it for 15 minutes has destroyed their engine. Best of luck.
    Raytheeagle likes this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
  15. Skibob
    2,912
    1,505
    Northern California
    OP. So what happened?
