Short trips? Here's a trick!
Discussion in 'Gen 2 Prius Fuel Economy' started by nooaah, Sep 19, 2008.
  1. nooaah
    nooaah New Member
    380
    Philadelphia
    Alright, when I'm at work I sometimes have to go to the orthodontist or run errands. These trips take me 1-2 miles, or less than 5 minutes total drive time. Killer on mileage, right? Yeah, it was for me, too. That is, until I figured out a little trick!
    If you have the time and patience, drive one block. Pull over and park. The ICE will shut itself off within 15 seconds. Sit there for a few minutes. After that, you should be ready to go. I can do a full pulse and glide with no problems. My mileage from these frequent short trips are completely unaffected.
    I hope this works for the rest of you! I also don't know if this will work well in cold weather. It's in the 70's-80's in Philadelphia lately.
  2. efusco
    efusco Moderator Emeritus
    19,885
    1,155
    Nixa, MO
    Yup, you've discovered how to get into S4...and once the ICE shuts off there's no need to wait...I typically just keep driving until I get to a stop light then I make sure to fire up the ICE and then let it shut off into S4.
    It won't work as well in cold weather and the distance needed to drive will vary quite a lot. What you're looking for is an ICE temp over 154F (I've heard 157, but I seem to be able to get into S4. This is yet another reason something like a scangauge is invaluable. You drive until you see 154/157F or higher before you try to get into S4.
    What I do on those very short trips with a cold ICE is I tend to use my EV button to simulate S4. The other day I did this for about a 2 mile drive and I actually never got the ICE temp up to 154 b/c I did short pulses and forced EV glides whenever possible on side streets.
  3. nooaah
    nooaah New Member
    380
    Philadelphia
    Unfortunately I don't have the EV button, so waiting out the warming time is my only option. This would work for longer trips, but it's not really worth the time, IMO.
    This has definitely helped my mileage tremendously, though. I get about 52MPG right now in a very hilly area and with my tires at 32PSI all around (I know, I haven't had time to properly inflate them). Before, I'd get about a .3 or .4 mpg hit from a short trip and about 100-200 miles on the current tank (fairly significant, I'd say). With this, my mileage stays the same or even goes up a little, depending on which hill I take.
  4. efusco
    19,885
    1,155
    Nixa, MO
    Again, it's worth the time, but not worth the time to take a stop just for the purpose of getting into S4 usually. Using my EBH I can usually stop at the stop sign for my little subdivision ~1/4 mile from my house. I make a complete stop, wait the 5-7 seconds (if my temp was up to >154), let her go into S4 then take off. It helps a lot on slower sections of my commute.
  5. nooaah
    nooaah New Member
    380
    Philadelphia
    Unfortunately, I have no way of gauging the temperature so I just estimate when it's ready to go at full efficiency. I see people using their mobile/palm devices to interface with the computer and get this information. Can a program do this via bluetooth or is there a more complicated hack involved?
  6. efusco
    19,885
    1,155
    Nixa, MO
    No hack really, you just need the cable/connector for the OBDII port and the proper software. But I strongly recommend the Scan Gauge...the amount of data and quality and convenience for the price is worth it...you'll have a hard time coming close with a PDA and the cost will probably being about the same.
  7. nooaah
    nooaah New Member
    380
    Philadelphia
    I've actually been tempted to buy one but I need more education as to what data it really provides me other than more accurate fuel usage...Which is an issue with my car. I get down to two pips with under 400 miles left. I refuel and can only put in 5-6 gallons before it clicks. I understand the whole "fuel bladder" concept but I think I'm a bit on the extreme end of things.
  8. ken1784
    ken1784 SuperMID designer
    2,940
    1,335
    67
    Yokohama, JAPAN
    I believe he was in S2 instead of S4.
    [email protected]
  9. efusco
    19,885
    1,155
    Nixa, MO
    Ken san, I hesitate to question you at all, but how could he do a full P&G unless in S4?
  10. ken1784
    2,940
    1,335
    67
    Yokohama, JAPAN
    Hi Dr. Evan,
    The S2 behavior is exactly same as S4 including a full P&G.
    [email protected]
  11. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I thought you had to be in S3 to be able to P&G. If I'm not at 155F(coolant temp) or above I can't P&G. Once I hit 155F, I can go into a glide if my speed reaches at least 35 mph. I was under the impression that S2 only meant that the ICE would auto-stop at stop signs/lights?
  12. rarthur
    rarthur New Member
    Newyork
    very nice.............
    Richard Arthur
  13. Neicy
    Neicy Member
    825
    Wakefield, MA.
    What about the 34 mph requirement along with the 154F temp? Thought that was a requirement too!
  14. ken1784
    2,940
    1,335
    67
    Yokohama, JAPAN
    Japanese NHW20 Prius can do full P&G in S2.
    Is the NA Prius different?
    [email protected]
  15. JimboK
    JimboK One owner, low mileage
    2,817
    180
    49
    Chesterfield, VA
    AFAIK, the only NA Prius that can do an ICE-off glide in S2 are those with EV switches. Are you able to do S2 glides without the switch?
  16. ken1784
    2,940
    1,335
    67
    Yokohama, JAPAN
    I didn't know that.
    Japanese NHW20 Prius behavior is...
    S1a:ICE-on at stop:no ICE-off glide:no ICE-off by EV switch
    S1b:ICE-on at stop:no ICE-off glide:ICE-off by EV switch
    S2:ICE-off at stop:ICE-off glide:ICE-off by EV switch
    S3:ICE-off at stop after several seconds(S3->S4):no ICE-off glide:ICE-off by EV switch
    S4:ICE-off at stop:ICE-off glide:ICE-off by EV switch
    Therefore, the Japanese Prius S2 behavior is same as S4.
    [email protected]
  17. efusco
    19,885
    1,155
    Nixa, MO
    I believe that in NA in S2 you can only get an ICE-off glide in S2 if you exceed 34mph then try to enter glide.
    I can never get an ICE off glide below that speed unless the ICE is above 154F and I've done a full stop and let the ICE self shut off during that full stop...S4.
  18. nooaah
    nooaah New Member
    380
    Philadelphia
    Maybe my car is Japanese because I can run fully on battery (99mpg) doing this. When I glide, I still end up in the 70'smpg but the fact that I can even black out the energy screen is better than what it was before!
  19. rolin
    rolin New Member
    long island new york
    I would be grateful if someone can explain "ICE" and all the abbreviations that are uses in this thread.
    Thank you
  20. nooaah
    nooaah New Member
    380
    Philadelphia
    Ice = Internal Combustion Engine
Loading...
