Should I be concerned with putting a lot of Miles on my Prius
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Feb 26, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    As has been said, the Prius is meant to be driven. If you're making lots of long trips, you're better off with a Prius than just about anything else on the road.
    51,769
    if you add up the $200. or so spent every time you rent, since the rental company is making a profit, it is likely less expensive to drive your own car, and retire it however much time sooner for a newer one.
    but if your goal is to preserve your car at all costs, leave it home and get another one for driving.
    or the answer could be somewhere in the middle.:p
  3. Mendel Leisk
    41,185
    We're doing a bit of alternate vehicle, skytraining to downtown events. Also, we rarely if ever use the car for short errands in the neighbourhood, say a sushi pickup two-three blocks distant; just hoof it.
    Skibob likes this.
    51,769
    highway driving is the easiest thing on a car. at least, that's what i've always heard.
    jerrymildred and Skibob like this.
  5. Mendel Leisk
    41,185
    Off-topic, just to share:
    The silver lining to my gaff, I learned how to cross out text. I've noticed others do that, thought it a good idea: leaving the text but putting a cross-out line through it, gives the reader a clear understanding of the edit history.
    Example:
    The quick brown fox jumped over the the lazy dog.
    Highlight the text you want to cross out, then select strike-through.
  6. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    What is a sky train?
  7. Skibob
    2,912
    1,502
    Northern California
    I have read that also but how does it make sense with a Prius? A Prius charges and discharges many times in a trip. It’s only small amounts but there a working battery’s out there with hundreds of thousands of miles.
  8. Mendel Leisk
    41,185
    Conjours up heady images. It's a magnet-impelled, driverless train system, sometimes at grade, or in tunnel, or elevated.
    SkyTrain (Vancouver) - Wikipedia
    Yeah I was doing the math this morning, thinking with daily driving, 365 trips a year, assuming at one full discharge per trip (thinking all the partials equal one whole), the battery would be toast in 3~4 years.
    Which is not typically the case. Maybe that definition of charge/discharge needs more clarification. Anyway, the message seems to be that usage wears down the battery. Maybe in particular if you have to haul the car up and down a steep hill daily.
    That's our grandkids transportation scenario btw: city planners of that community in their wisdom put the middle and high schools waaay up this hill. Pretty much as high as they could go. So everybody and their uncle are hauling tons of steel up/down this blinking torture track twice daily.
    Luckily it's rare event we need to go up there.
    #28 Mendel Leisk, Feb 27, 2019
  9. Skibob
    2,912
    1,502
    Northern California
    Nice! And it appears to be inexpensive to ride also. To take a train from Sacramento to Davis is 16 dollars, it’s only 1 stop.
  10. qettyz
    qettyz Active Member
    181
    206
    Finland
    I didnt even know that there is button for that on this forum software.
    I always code stuff straight away to the text while writing, like
    Code:
    [S]striked out text[/S] and normal text
    #30 qettyz, Feb 27, 2019
    kenoarto, bisco and Mendel Leisk like this.
  11. Mendel Leisk
    41,185
    On weekends/evenings it's a lot cheaper, no extra charges depending on number of zones, just one base rate. And for me, being over 65, I pay the same as kids, around $2 now I think. Handy too, you can get a card, just swipe it getting on/off. And can be set up to auto replenish from your credit card.
    Also tracks your usage, so if you're a contract killer on the job, for example, you'd want to leave the card at home, use cash. :coffee: Sorry, watching too much Behzat C.
    I'm likely to be arrested for off-topic crime. :oops:
    #31 Mendel Leisk, Feb 27, 2019
    davecook89t, jerrymildred and Skibob like this.
  12. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    The first one was replaced in the recall so technically only one failure (2nd) a couple of months ago.
    FWIW
    SFO likes this.
  13. jerrymildred
    11,517
    14,147
    Tampa, FL
    Ah ha!! I hadn't checked on the cross hairs to see what's behind them. Thanks.
    Yup! I've read that taxis get hundreds of thousands of miles on the original traction battery.
    Raytheeagle, Mendel Leisk and Skibob like this.
  14. TinyTim
    TinyTim Active Member
    380
    231
    Seattle
    No offense intended to Gen 3 and Gen 2 Prius owners. You should drive the hell out of a 2009 Prius while you can before the battery on it dies. It seems that once people get to 10 years old or more. That is when the Prius battery approaches the coffin's corner.
  15. Skibob
    2,912
    1,502
    Northern California
    Fortunately a new battery is only 1714.48.
    Battery - 2004-2009 Toyota Prius (G9510-47031) | Tracy Toyota
    And not that hard to replace.
  16. Leadfoot J. McCoalroller
    8,050
    7,528
    Pennsylvania
    2018 Prius c
    Do you want an old Prius going to the crusher with a few miles on it, or an old Prius going to the crusher with a whole bunch of miles on it?
    That's the real question. Age hits these cars harder than miles. No sense in saving it for later, use it or lose it.
  17. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    I decided to move my interview but will be traveling to Pittsburg which will be about a 10 hour drive. I can't wait! I love my Prius so far hope it will last
    bisco, SFO, Skibob and 1 other person like this.
  18. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    2005 battery still going just fine here.
    bisco, jerrymildred, SFO and 2 others like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Our 2010 is about to hit 200k miles :).
    And in the original pack performing like new;).
    I just hope the engine lasts as long as the battery does(y).
    Skibob, jerrymildred and SFO like this.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    IMO 71,000 miles on a 2009 Prius isn't bad.
    I'm going to make the assumption that the worry isn't about the miles currently on the vehicle but adding miles with long road trips. I guess my question is, do you expect your driving habits to change or adjust?
    If after a few of these road trips, your driving pattern is going to adjust I wouldn't worry about it. If you foresee one long road trip after another?
    Then whether you want to rent a vehicle to take the mileage off your Prius is up to you. Personally, I felt the Prius was THE best road trip vehicle I ever owned. So I would lean towards using it.
    Graeme1949 likes this.
