Should I buy a 2007 Prius with hymotion installed?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Chinua Mosley, Feb 21, 2013.
  1. Chinua Mosley
    Chinua Mosley New Member
    Hi.
    I'm a Prius n00b and I'm in need of some advice. I'm looking for a new car and I came across a 2007 Prius with $46,000 miles on it and a hymotion system installed in it. It's being sold by a dealer who does not know much about the system for about $16,000. Here are my questions:
    1. If I go to check out this car, how can I tell that the hymotion system is even working?
    2. How reliable is the hymotion system? (I've seen mixed reviews)
    3. Would it be possible to still replace the batteries and so forth even though hymotion doesn't do conversions any more?
    4. There are no certified hymotion installers near me. Should that be a concern for getting it serviced?
    5. How does the hymotion system affect the car getting regular servicing from Toyota?
    6. Without talking about the DC to DC converter issue messing up the battery, how long have people actually experienced battery life on the Hymotion?
    7. If I buy this car, what issues (big or small) should I look out for?
    8. If I buy this car, what third party add-ons would you recommend I get to get the most out of it??
    I have never owned a hybrid before, but I'm very interested in the technology and am looking to get the highest mpg possible.
    Thanks,
    C. Mosley
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Hymotion is not in business anymore. Their packs are reliable if you treat them nicely, meaning do not fully charge, and do not fully deplete. However, they allow you to squeeze every drop out of the pack if you want to, and most people do which in turn destroys the pack fairly quickly (< 1000 recharge cycles, or if 1 time per day, 3 years). If you know nothing about how it was treated previously, and how many miles are on the conversion, I would run away and leave it to someone who has time to tinker when it inevitably fails. It is a great system with lots of holes for user and self inflicted destruction possibilities. That's why they are no more...
    52,927
    maybe offer the dealer what it would be worth without the system?
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep. Even though the Hymotion system seemed the most reliable out of the plug-in add on packs, some have had failures and yes, it's no longer produced and A123 Systems even filed for bankruptcy, but the remnants aren't dead.
    I would basically not pay any more than for a car w/o it, because if it fails, it may not be worth the expense to get it fixed. If that's the case, remove it, instead of carrying around dead weight.
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I thought the Hymotion system actually replaced the traction battery with their own LiFePO4 version (A123 cells), so there is no NiMH traction battery anymore. So you cannot remove it without buying another normal traction battery.
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    No, it doesn't. At least not from my re-skim of REVIEW: Hymotion Battery Plug-In Prius | PriusChat.
  7. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
  8. patsgarage
    patsgarage Junior Member
    We were Hymotion's first dealer back in 2007. I have been driving my conversion since then with very few problems. First of all the Hymotion system is quite nice. I am not an avid eco driver but I still regularly get around 75mpg driving up and down the hills of San Francisco. Like all new technologies it has had it's share of teething issues. It will not be as trouble free as the Prius itself. If you are not interested in at least a certain level of DIY activity I would not take it on. That doesn't mean you have to want to put on the high voltage linesman gloves and dig but it does mean you will need to educate yourself on how the system works, how to maintain it, etc. Where are you located? I can maybe suggest someone nearby who knows something about the system. If the system fails entire you can still get a rebuilt system for around $3500 installed depending on where you are located. Feel free to email me directly if you have any questions:
    [email protected].
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Does the Hymotion system use OOG mode?
  10. Chinua Mosley
    I'd first like to thank everyone for your input. @ patsgarage I live in the Atlanta, GA area. Since you are familiar with the system, can you tell me how to know if the system is functional if I go and check it out?
