Should I buy a Prius?
Discussion in 'Gen 2 Prius Main Forum' started by pault842, Sep 3, 2006.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(pault842 @ Sep 10 2006, 01:58 PM) [snapback]317453[/snapback]</div>
    Push the power button with your foot on the brake, when it starts you will see a "ready" light with a rectangle around it. If you push the start button once without the brake you go into the accessory mode; if you push twice it goes into what I think is called the "ign on" mode which means the ignition is not on, it looks and acts like it's on except the ready light isn't on and you can't get it in gear. You can go to "ready" from either of those two modes just by pushing power again with the brake on. The owners manual will tell you more when you get it.
    I'll let the audio guys answer your DVD question.
  2. sharkmeister
    sharkmeister Junior Member
    56
    For me the key thing would be that the Prius is holding its value terrifically well.
    Buy the Prius, drive it around for 6 months, and if you don't like it you can sell it for very nearly its new cost and get the other one.
  3. Starfall
    Starfall New Member
    215
    Post deleted.
