Should I buy Prius Prime or regular Prius
Discussion in 'Gen 4 Prius Main Forum' started by 310 Prius Owner, Jan 10, 2022.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Yeah I'm learning that if I go out and come back home it's typically about 10-15 miles of driving. If I know I'm going back out later in the day I can plug in and get enough charge in it for that 2nd trip usually. It's a game of deciding when I can use what's left in it or if I need to charge a bit before going out again.
  2. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    It's not really much of a game. I plug in the car whenever I get home, so even if I'm home only 15 minutes, that's an extra couple of miles that I can travel. Rough calculations say the car gets about 10 miles of range from each hour of charging with a level 2 charger on a 220v circuit.
  3. don_chuwish
    823
    190
    Southern Oregon
    Yes, having a Level 2 EVSE does change the situation. I’m still on the 110v wall socket. Also I prefer to run the SOC down low before fully recharging but I may get over that in time.
  4. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    One of the advantages of plugging it in every time is that it becomes a habit. You stop noticing it after a while. :)
  5. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    Toyota have withdrawn the “Regular” Prius from sale in the UK.
    I believe the US is going the same way soon.
  6. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    That is unfortunate but likely inevitable,
    My hope was the standard Prius would become a small battery PIP.
    But if they are all Prime that means you may get some new Prime trim packages and AWD.
    My worry is that the Prius brand goes the way of the Dodo
  7. PaulDM
    616
    320
    UK
    2022 Prius
    Excel
    Or the way of the Pinto
  8. DOHCtor
    DOHCtor Active Member
    170
    104
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Strictly from an efficiency point. If you only do lots of highway miles a vanilla Prius is lighter and should get better highway MPG's.. If you only do city miles, time is a luxury you got and you can recharge.. Prime it is!
    Personally i chose a Prime as we have employee chargers at work and a 6k bucks government rebate. Free electricity!
  9. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    All the web sites (including fueleconomy.gov) show slightly higher mileage in the prime. I recall hearing that the larger battery lets the Prime do a better job of buffering energy and regenerative braking.
    Rmay635703 and jerrymildred like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    You would think so, but we have both a Prime and regular Gen 4. The Prime gets consistently better mpg on long road trips as well as in HV driving around Tampa on 45-60 mph roads.
  11. DOHCtor
    170
    104
    2024 Prius Prime
    SE
    Really, i'll have a closer look but i think i saw better milleage on the vanilla in those brochures at work. I'll have a second look as i might have switched the 2 of them.
  12. jerrymildred
    11,517
    14,171
    Tampa, FL
    Unless Canada uses different numbers from the US, you switched them. Although the ECO does get better EPA numbers. And then there's the consideration that cars don't always obey the commands of the brochures. :D
    Here's the 2019 Prius (my most recent brochure):
    And the 2018 Prime (my most recent brochure):
    Screen Shot 2022-02-03 at 7.42.35 AM.png Screen Shot 2022-02-03 at 7.42.54 AM.png
