Should I change 17 y/o brake fluid
Discussion in 'Gen 2 Prius Main Forum' started by nancytheprius, Apr 11, 2024.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    I would open a bleeding valve at a time at the caliper and pump the brake pedal until the brake fluid coming out is the same color as the one I added, while keeping adding fluid in the reservoir so not to introduce air in the system. Best time is when changing/rotating wheels since it's easy to access the bleeding valve with the wheel off.
    51,948
    that's not toyota, that's a dealer putting words in toyotas mouth.
    i wonder if gen 4 or 5 maintenance schedules have recommendations.
  3. Dduelin2
    Dduelin2 Junior Member
    23
    N Florida
    Read down through the many many search hits. The link was a Google search. Even if Toyota still doesn't give a recommendation brake fluid is hygroscopic and absorbs moisture. It's an industry recommendation not to go 17 years even if Toyota doesn't give a firm one.
  4. Mendel Leisk
    41,463
    ^Just editorial.
  5. Mendel Leisk
    41,463
    I just change the fluid, pumped out through the bleeders, per the non-Techstream method, albeit with a baste out and refill of reservoir at the outset. A couple of times now, on our ‘10.
  6. bisco
    51,948
    agreed, it is odd that they do not, i can't think of a reason
  7. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    Recently did!
  8. VelvetFoot
    VelvetFoot Active Member
    693
    252
    New York State
    2026 Prius
    Never knew that, thanks.
  9. BiomedO1
    BiomedO1 Senior Member
    3,626
    1,872
    SacTown, Ca
    It's called lowering maintenance cost; that's the same reason oil changes was moved to 10K miles. It lowers the TCO (total cost of ownership). Some consumers are actually getting smarter and looking at that.
  10. bisco
    51,948
    what are the symptoms of bad brake fluid? i've gone 11 years without changing it
