Should I do an fast flush on a neglected motor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Mar 22, 2017.
Tags:
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    doing full maintenance on a 2008 with 157,000 miles, motor oil wasn't changed regularly but when it was it was over filled, oil pooled in intake manifold, PVC valve caked with crud, oil was jet black. spark plugs look to be original (changed them).just wondering if it would pay to use a fast flush on it or just do a few extra changes at around 2000 miles and let the crud work itself out over time..
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Not a big fan of using anything to flush the engine oil since removing alot of crud at once can cause some issues, definitely prefer to just use some higher detergent oil with short change interval then switch to synthetic oil after. You can use flushes in some extreme cases but often times anything that can be a solvent to sludge will also attack the engine seals too.
  3. Beachbummm
    1,160
    392
    that's what I was thinking too just wanted a little more input on it.. thanks
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    There's always a pool of oil in the bottom of the throttle body.
  5. Beachbummm
    1,160
    392
    there shouldn't be...
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    It's part of the Atkinson cycle weirdness. They all have it. When my car was brand new it had it.
    So disregard it as a symptom.
    m.wynn likes this.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Hot Shot oil addative will do best in this scenario....do some research on your own.....I use this on all customer car's that have been abused or neglected....
    You will need 2-3 oil filters before oil change..depending on buildup inside of engine....one at addative use and one more at about half cycle before oil change minimum...this addative really clean all out.....
    Can you post pictures.....
    I have looked on my wife Prime with 4000 miles now...and all weaknesses people reported so far and found nothing in this nature
    My next project is installing oil catch can....this is good for not just this engine but with any engine
    Beachbummm likes this.
  8. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Ed is correct, this is completely normal with regard to gen's 2 and 3 as I've verified with our '07, '10 and '11. None have been neglected and all 3 live on name brand synthetic at 5k mile OCI's. The "07 burns 16-20 ounces of oil per interval and neither gen 3 burn a detectable amount. Thus, I don't think oil burning plays much, if any role. It's possible this has somehow been designed out for gen 4 but I doubt it. When SAMPRO gets up around throttle body cleaning time mileage, I'll bet he observes the same oil pool. "Atkinson cycle weirdness" seems to be about as good an explanation as any.
    #8 m.wynn, Mar 25, 2017
    Raytheeagle, edthefox5 and Beachbummm like this.
  9. Beachbummm
    1,160
    392
    OH, OK, with all the dirt and oil I got off the mass sensor and clogged PVC valve I though it was a problem. learn something new all the time
  10. Samprocat
    491
    297
    Lincoln, NE
    All engines are mandated to have crank case recovery rooted back to combustion side.....there is way to keep this nasty staff entering intake side....oil catch can.. Not hard to do and is doing good job
  11. edthefox5
    10,096
    4,837
    Clearwater, Florida
    It's not nasty if you use synthetic oil. My car is a good g2 test bed as I bought it new and it's lived its life on high quality oil. TB never looked nasty although I have cleaned it a few times. Each time I flushed out the inlet pipe that connected to the PCV valve and it was not bad at all. It's not like it was 50 years ago when oil was horrible and leff a burnt residue behind after 3000 mikes on a hot running motor, plus emissions regs came along and you couldn't vent the motor to the atmosphere.
    Invention of Mobil 1 was a godsend back in the day.
    So my point is a catch can is useless unless your running some really crappy oil and the TB is struggling with all that residue. And your bypassing emissions by lettting the pcv valve vent to the atmosphere.
    m.wynn likes this.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I see on the Corvette forum guys with brand new c7 corvettes are running oil catch cans as under hi rev there losing oil.
  13. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any updates or photos of that oil catch can install?
    Raytheeagle likes this.
  14. Prodigyplace
    12,708
    11,847
    Central Virginia
  15. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Been there before, but was curious about Prime or Gen2 installs (was secretly hoping @Samprocat has a Gen2 next to the Prime).
    Pictures would've told the story either way, and everyone enjoys seeing how others go about their modifications or installs.
    Might end up having to blaze the Gen2 oil catch can trail. Though curious, I doubt there will be much oil/water caught in the can.
    Raytheeagle and Prodigyplace like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I was scoping out a good location on our 2010 this morning;).
    Did that while finishing up the fence build:
    7C93F11E-2788-456C-84AF-D689BFAA3057.jpeg 64D9FDD9-AD71-4AFC-BD49-6F3FEF47125E.jpeg
    Busy couple of days (y).
    m.wynn and SFO like this.
