Should I fix or sell?
Discussion in 'Gen 2 Prius Main Forum' started by ohsix2006, Aug 11, 2022.
  1. ohsix2006
    ohsix2006 New Member
    Michigan
    I have a 2006 Prius that I've had for 2 years and put about 20k miles on. She's at 210k miles and I've not had any issues with her.
    A couple of weeks ago I got the triangle of death, ran the codes myself and got a P0A80 replace hybrid battery pack. Took it to the local hybrid shop for confirmation after looking at it, they refused to work on it because they say she probably had a rodent infestation at some point (but they couldn't find any chewed wires or physical evidence of this) so replacing the hybrid battery would likely be a temporary fix, something new would go bad soon, and it would end up just costing me a lot of money.
    Thoughts on this? I am thinking about selling for parts. Or should I take the chance and replace the battery? I only need it to last 9 more months before I was planning on selling anyway.
    Would appreciate any/all insight.
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    If they couldn’t find evidence of chewed wires, did you ask them why they thought it was rodent damage?
  3. ohsix2006
    Michigan
    They said it was because my car kept kicking their computer out when they were trying to diagnose the issues and they've only seen that happen when there's rodent damage, but they looked and couldn't see any evidence of chewed wires or anything.
    52,754
    if it's running well, and not burning too much oil, i would either diy repair the battery, or get a refurb replacement from a reputable company. 210k is not a ton of miles.
    to get started, you will need tech stream for proper codes and sub codes.
    as for rodents, they are popular, but without evidence, i wouldn't worry about it
  5. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    You have a few options:
    Find a good, experienced Prius shop which will work with you. They are rare.
    Learn to fix it yourself. The learning curve is steep, daunting, and will take you a while,
    Just keep running it. Learn how to clear codes (temporarily) with a scanner, or by disconnecting the 12v battery. You can probably get away with this for 3 months. I've got away with it for 2+ years. But you will still have (more brief) learning curve.
    Sell it to a Prius DIY person with full disclosure. You will have to learn how to negotiate. If the car is as good as you say, the battery issue is inconsequential to a DIY person. But they won't tell you that!!
    Sell it to Carvana or some other scum used car place. This will bring you bad karma because they will do a hokey, useless, cheap, temporary fix and sell it to a college student buying her first car.
    Do not sell it to such a college student yourself. This will triple your bad karma.
    You do not need to part it out.
    Keep your options open for vital trips - Uber, friends, rentals as fallback backups.
    Good luck.
    There is a lot of good advice on PriusChat but many of the advisors have a lot of resources and experience - see "learning curve" above.
    Contrary to some (smarter people than me) I think 200k miles is about the limit on these cars. After that there are a lot of problems, some very complicated, some very expensive. This is NOT a simple vehicle.
    #5 JohnPrius3005, Aug 12, 2022
    tracy ing likes this.
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Which part of Michigan are you near, as another member may be able help.
    FYI : you're moderated until you've posted 5 times.
  7. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    A bad 12 volt (reg car battery) will cause ALL KINDS of issues. More so on a Prius than most other cars.
    I'd check that first.
  8. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    So far the only thing I experience with two of these that went way beyond 200k is drive train steering suspension wear out. Those parts are cheap enough new for after market. I havent had any of the issues some have with electronics or pumps or weird prius cooling systems etc etc being an issue.
  9. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    based on my experience buying old and high mileage past 200k+ Priuses -
    - wheel bearings at the front will go out, this will cause noise, howl, grind and abs/vsc to light up
    - rear drum brakes needs servicing
    - hid lights flickering (even at low miles)
    - instrument cluster will turn off (capacitor issue)
    - blower motor will make a noise
    - inverter coolant pump needs to be replaced
    - timing chain might stretch (not following oil change intervals)
    - interior will be worn out, they are cheaply made.. worst than Volkswagen or domestic brands (Chrysler/Ford/GM)..
    which are very basic issues, so far I haven't experienced major issues such as brake actuators failing or inverter replacement. I did replace the timing chain components on my very 1st one because the chain is stretched causing a check engine light. The 1st 2 Priuses I sold to my friend still has good hv battery (not sure if they were replaced) past 240k miles even with the 12v.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Do you need a car now? If you sell, can you replace it now?
    A working car will sell for more than a broken one. It's up to you to decide if getting 9 months of use and higher resale is worth fixing it for you.
    Who knows when the used car bubble will burst?
  11. tracy ing
    384
    173
    wash dc
    yeah no big deal, like changing a tire, much easier than most of the vids out there show you
    I can change both fronts in 1 hour. Have done 5 cars. cheap too for good parts, about 150 a car with quality parts
    - rear drum brakes needs servicing (mine needed this 2 years ago i am ignoring it lol (SQUEEL when wet and locks up)
    - instrument cluster will turn off (capacitor issue) had this on the 2008 we just got, drove the display to west va he replaced the component in 5 minutes)
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Curious what is considered quality (or even good) these days, and how the replacement parts on the 5 cars have held up over the years.
  13. tracy ing
    384
    173
    wash dc
    TRQ
    Trusted Reliable Quality
    brand i have used, they hold up, wheel bearings cv axles etc
    and MOOG
    most of the wheel bearing videos are wrong, they have you take all kinds of stuff off, you dont need to remove
    from memory
    remove the wheel, remove the caliper and let it hang, remove the abs sensor, remove the axle nut, remove the two bolts on lower shock so the wheel can be forced down and away from the axle, makes just enough room to push the axle out. there is a dust cap on the inside you have to pry out gently, once the cap is loose you can get a wrench on the 4 bolts on the bearing housing, then i use an air chisel to work the bearing housing back and forth, once it breaks loose comes right out, its aluminum in steel so it corrodes and is a bear. air chisel persuades it. I can get one side done in 30 minutes.
    make sure to ALIGN THE DUST CAP or you will be buying an ABS sensor
    #13 tracy ing, Aug 13, 2022
    SFO likes this.
