Should I get a ScanGauge II or ScanGaugeE?
Discussion in 'Gen 3 Prius Technical Discussion' started by kalome, Aug 3, 2012.
  1. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    And why?
    I see the "E" has a Scan Tool like the SGII.
    The ScanGauge II is 65 dollars more than E.
    Is it worth the extra 65 dollars?
    Your thoughts...Thanks!
  2. gliderman
    gliderman Active Member
    751
    225
    II, or both. E is for empty.
  3. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    No need for any responses. I have decided to go with the II
  4. fuzzy1
    10,713
    Unless you are directly supporting the PCshop, I hope you don't pay more than $134.95 for the II.
  5. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Where can you get one for 134.95 or less?
  6. fuzzy1
    10,713
    First, I'd encourage readers to be loyal to Danny here at the PCshop. (I bought my ScanGauges before developing loyalties to PC, but have since spent even more in the PCshop.)
    For the less loyal, consider supporting Wayne Gerdes at CleanMPG.com. Look down the right hand side for a members only fund raiser, it can't be displayed on the base page.
    For the very frugal with great patience, apparently this shows up occasionally even cheaper as a limited time deal on Amazon.com. I have no idea how long you need to wait for it to return, or how frequently (daily or every few hours) you must check to be certain to not miss it.
    kalome likes this.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    fuzzy1 and kalome like this.
