Should I get my EGR system checked/cleaned?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KevinG, Sep 17, 2024.
  1. KevinG
    KevinG Junior Member
    St. Louis, MO
    We have a 2012 Prius we got used with like 35k miles.
    In June 2019 (@ 87k miles) we had this intake /induction cleaning done at the dealership as described in this picture.
    We now have about 123k miles on it.
    I taking it in for an inspection and possible brake service tomorrow and I’m wondering if I should get the EGR system inspected/ cleaned? I assume to inspect the EGR system you have to take it apart, at which point actually cleaning it is only a small amount of additional labor, correct? Or would this cleaning the dealer did 36k miles ago have prevented EGR clogging issues?
    Money is tight for us so I don’t want to spend money on something that doesn’t need to be done, but on the other hand we REALLY can’t afford a big repair like replacing a head gasket.
  2. KevinG
    St. Louis, MO
    Dangit I can’t get this image to display correctly. I’ll have to fix this later, I gotta get back to work now
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    For the money the shop will charge you for cleaning (IF they really clean it) you can buy a new one /
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Not sure what they did, or cleaned, or whatever.
    If you search junk yards around the country you can find a cooler for well
    under $100. And you can get an intake manifold also, not sure of a price though.
    You can clean these parts, and give them to the place you take your Prius and have them
    replace them and clean the pipe, which should only take a few minutes.
    Then you can clean the other coooler and manifold, for the next time.
  5. KevinG
    St. Louis, MO
    Ok so the dealer service invoice says they did:
    “Engine performance restoration service – helps clean both smaller Oil passages for hydraulic actuation and oil control rings
    Fuel induction service – helps Reduce carbon deposits on fuel injectors/engine valves and intake manifold”
    And again, this was 36k miles (5 years) ago
  6. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    When I cleaned my EGR a couple years ago now it was barely dirty, nothing clogged. I've seen some pictures on here where it's scary looking! Make me wonder if the type of gas used is why. I only use top tier gas.
  7. Mendel Leisk
    42,347
    At what miles? Never cleaned before?
  8. bisco
    52,855
    it's not worth the risk of a blown head gasket. if you're going to keep it, get it done, but make sure the understand the intricacies and nuances.
    but keep in mind you're heading toward possible hybrid battery and brake actuator territory
    Danno5060 likes this.
  9. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    The more work I have done by a shop, the more I learn that I shouldn't trust shops to do the work.
    Don't trust any shop to do more than the absolute minimum. If they didn't explicitly say they replaced the EGR valve, and they soaked the cooler, I wouldn't take it as meaning more than they gave them a quick shot of compressed air.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    No they did not clean the egr, egr cooler or intake manifold with that largely unneeded chemical treatment that takes them maybe 30 minutes. To clean the egr system and intake takes four or more hours and a dealer will only replace parts. The egr valve and intake have revised parts. Another thread on here today has a woman getting charged $2k for the egr valve and cooler alone.
  11. Mendel Leisk
    42,347
    Yeah do it yourself, budget a weekend, especially the first time 'round. See top two links in my signature for tips/links/info. Especially: there are things you can do in advance, before you dive in, to make it go much quicker. Things that don't disable the car in any way:
    1. Remove EGR cooler lower bracket nut and associated stud. (just leave it off permanently) Note: remova of this stud this will allow you to pull the EGR cooler straight out, without removal of the rear studs, and greatly reduce the chance of the rear gasket dropping down, getting lost.
    2. Remove EGR valve nut and stud, clean threads on stud, reinstall both.
    3. Remove EGR cooler upper bracket bolt, clean threads, apply light coat of anti-seize, reinstall.
    4. Get all the tools and cleaning supplies ready. (see top two links in my signature.
    I'd strongly suggest to have both Oxi-Clean Versatile Stain Remover (powdered laundry additive) AND lye crystals (available on Amazon) on hand, for the EGR cooler cleaning. A bottle of the Toyota Super Long Life Coolant (pre-mixed) is good to have.
    Also a clean container and some clear vinyl tubing, sufficient to collect 2 quarts/liters of coolant from the radiator drain. This partial drain will completely negate coolant spillage, can be poured back into reservoir afterwards.
    (If on a phone turn it landscape to see signatures)
    When doing the main job, start with removal of the EGR cooler, and get cleaner soaking in it ASAP. Depending on condition that could be Oxi solution, or if heavily carbon-clogged, lye solution. Be VERY careful with the latter, read up on proper method to mix, safety precautions. See links in my signature for more info.
  12. HondaTheNextOne
    HondaTheNextOne Junior Member
    45
    Tennessee
    From what I’ve learned, just go ahead and replace the parts now, as opposed to cleaning them. Just be sure you do t skimp on the parts otherwise things may get worse in the long run.
  13. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Hmm, I'm at 160k miles now, so was about 140k I think. No, it was never cleaned before.
