Should i go to higher viscosity oil?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jim Caldwell, Oct 10, 2020.
  1. hill
    9,039
    yet modernly .... they're going even thinner !
    Sure, part of this is due to carb regulations, but part of it also is that Machining technology has greatly improved. That means tolerances can be very very tight, necessitating the lighter viscosity. Ie 2 rationals for watery thin
    #21 hill, Oct 11, 2020
    Michael Wood likes this.
  2. Mendel Leisk
    42,352
    Is this ever-thinner oil similar to low tension piston rings: earns the car manufacturer high mpg accolades, and the purchaser picks up the tab with the engine failures?
    scona, m.wynn, pjksr02 and 1 other person like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Just put 80W90 gear lube in it, that will stop the oil burning... :whistle:
    Attila Fekete and Grit like this.
  4. gliderman
    gliderman Active Member
    751
    225
    I know its satire, but do not put gear oil in any part of an ICE. The composition is such it will be worse than any other motor oil you might possibly use. YMMV
    Northshore_Paul likes this.
  5. ASRDogman
    8,066
    4,089
    OH MY GOSH! IT WAS A JOKE!
    Toyota, in America says 0w20. So anything else will destroy the engine!!!!!!
    PANIC EVERY PANIC!!!! :eek::eek::(:(:confused::confused::barefoot::barefoot::cry::cry::coffee::coffee::coffee::coffee::coffee:
    Grit likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ahh!!!! The oil apocalypse is here, run!!!!
    I get the same type of responses so I’ve been in those shoes.
    ASRDogman likes this.
  7. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    One litre is about a quart, is that correct?
    One quart in 6000 miles doesn't seems so bad to me.
    The 0 in 0-20 represent cold oil viscosity.
    Something to consider concerning the start stop functions.
    I don't think going to 0-30 or 0-40 will reduce that oil usage in any large amount.
    Therefore, personally I would remain the Toyota's specs/ suggestion chart.
    Yet I don't think a change to 0-30 would cause any harm.
    And again personally I would definitely not change to a 20-50.
    Good luck in you decision.
    Jim Swart likes this.
  8. ASRDogman
    8,066
    4,089
    About 1.06qts in a liter
    About 0.95 liters in a quart...
  9. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    As far as I know the to fill an empty engine needs less than 4 quart of oil. So missing ~25% sounds significant to me.
    But if it’s between the max and min sign of the oil stick, then it’s acceptable.
  10. SB6
    SB6 Member
    324
    71
    To be exact, the car takes 4.4 US quarts, or 3.7 imperial quarts, with an oil & filter change. Here's what the repair manual states:
    Page 4043 of 7595 in the 2010 Toyota Prius repair manual
    #30 SB6, Oct 12, 2020
  11. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    All these specifications, which are listed in everyone's owner's manual, are nice to know, and I commend everyone who took the time to look up and quote these. But didn't the original problem result from the OP not checking his dipstick over time? I'm going with "read the dipstick."
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Agree. There are many posts stating “a rod blew through the engine” of without saying “I don’t check oil levels often or at all.” They blame it on the engine and how crappy it is.
    pjksr02 likes this.
