Should I keep fixing it?
Discussion in 'Gen 3 Prius Main Forum' started by douglasjre, Apr 16, 2026.
  1. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    I have a third gen Prius with approximately 300,000 miles. I don't know because the mileage isn't shown anymore. Things currently broken include the multifunction display, the right rear window switch located on the driver's door card, the power steering rack is clunking and sloppy, the paint has peeled off, the subframe is bent so much that the plastic bumper cover doesn't even meet the subframe anymore, the front bumper cover looks like it's going to fall off soon in nine different locations and yet it still held on by zip ties, the suspension is starting to wear out again, the battery pack has already been replaced with an aftermarket pack brand new, break actuator/accumulator and abs assembly have been replaced, inverter converter assembly has been replaced, the 12 volt battery has been changed two times. The first engine already got a head gasket and then ultimately that went bad as well and I had to put any used engine 70,000 miles ago, the stereo display isn't readable anymore and some buttons don't work, the AC display is faded and unreadable, the steering wheel and driver seat look like crap, the entire interior looks like shit, somebody lost the shock absorber from the glove box door so it just pops open, the tray is missing from the armrest compartment, there are numerous dents and scratches all over the car, some of the third brake light bulbs are burnt out, the air conditioning tubing has been creased and probably restricts its flow somewhat, the brakes have been changed but that doesn't really matter in the big picture. Oh and the clock wire behind the steering wheel has been replaced before and none of the steering wheel buttons work anymore in spite of that fact because the steering wheel buttons are worn out, the stereo is worn out, the multifunction display doesn't show mileage anymore and some of its elements are burnt out. So what do you think should I keep fixing things and keep it running? Or should I toss it the next time something major goes bad?
    #1 douglasjre, Apr 16, 2026
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,334
    957
    Monument, Colorado USA
    Well, at 300,000, you've definitely gotten your money's worth, and then some, out of her! But, of course, the sentimental value, and memories, are still there.
    It sounds like a whole lot of her has, already, died....but it's your call!
  3. Tombukt2
    Tombukt2 Senior Member
    13,804
    2,504
    Durham NC
    No siree!
  4. Mendel Leisk
    42,254
    It sounds like your skill level and tenacity has lumbered you with an indestructible beast.
    I do somewhat similar, albeit on a much more simplistic level: more than one of our knackered home appliances soldiers on without on/off switches. If I can find 'em I'll replace 'em, but if not, hey: it turns on when you plug it in. :)
    douglasjre likes this.
  5. bisco
    52,773
    300k is a great run, move on if you can afford it.
    Brian1954 likes this.
  6. PriusCamper
    PriusCamper Senior Member
    13,402
    5,412
    Pacific Northwest, USA
    Time to start over... With the next car you get fix things as they break and don't procrastinate. I always explain to people who don't fix the minor problems on their car that when the big problem comes it won't just be one big fix, but so many things beyond that one fix that they're better off starting over, which is way more expensive.
  7. douglasjre
    2,246
    751
    Null, NL
    I've also cleaned the complete EGR circuit . The paint is gone, front bumper ruined, subframe bent, switches don't work, buttons don't work, and steering rack makes a rackette, lol. Next big thing breaks i think I'm calling it quits
  8. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Compared to that long, sad list, my 2011 is still almost like new, except for the paint.
  9. BiomedO1
    BiomedO1 Senior Member
    4,515
    2,375
    Left Coast
    Your sub-frame issue may have something to do with your steering issue and I'm surprised it's not eating tires.
  10. GFO
    GFO Member
    83
    56
    Larkspur
    You could for shits and giggles see what Carvana will give you for her. Might only be $800.00, but that's better than having to pay someone to take her to the scrapyard.
    Merkey likes this.
  11. rjparker
    rjparker Tu Humilde Sirviente
    10,995
    6,892
    Texas Hill Country
    douglasjre and Merkey like this.
  12. douglasjre
    2,246
    751
    Null, NL
    B
    #12 douglasjre, May 16, 2026
  13. bisco
    52,773
  14. rjparker
    10,995
    6,892
    Texas Hill Country
    BD
    Birthday
    Baby Daddy
    Black Disciple
    Bis in die (twice daily)
  15. bisco
    52,773
    bisco and doug
