Should I keep running e85
Discussion in 'Gen 2 Prius Main Forum' started by sithlord_master, Apr 14, 2007.
  1. Squint
    Squint New Member
    66
    Why bother asking if your mind is already made up?
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(qbee42 @ Apr 15 2007, 08:56 AM) [snapback]423616[/snapback]</div>
    And when he does experience system failures, he will blame it on Toyota and file a law suit.
  3. Macomb
    Macomb Junior Member
    42
    upstate New York
    Four Touring
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Apr 15 2007, 12:19 PM) [snapback]423626[/snapback]</div>
    WRONGO, 1stAmeriPrius. I'm not sue-happy nor do I blame others for my actions and the consequences of my actions (if any, real or imagined). I have made my choices based in information I have. I will definitely keep you all informed, but it IS afterall a car and a mechanical one at that. It does have a defined lifetime. How many of you on here are planning to keep your vehicles for eight or more years? I plan to keep mine for that long, repairs and all, and I DO assure you it will require repairs--all vehicles do. Simply put, I do not believe I'm hastening the frequency of any repairs by using available fuels that run just fine in the vehicle. I've noted in the past that some of you believe strongly in fuel additives as well as in modifying/tinkering with your cars. That's your right. If it 'voids the warranty', you've made a conscious decision that you're willing to void the warranty.
  4. airliner53
    airliner53 Junior Member
    17
    My wise old father always told me there were cerrtain people you would not want to buy a used car from ...
  5. cc9150
    cc9150 New Member
    44
    Me.
    I know it's unfashionable, but if you buy right and maintain it, you spend less money overall.
    And a car is nothing but an expense. It's wise to minimize that expense. In other words, be smart.
    It's those who vote with their emotions and think they have to have new every 3-5 years that are in trouble.
    They're also ruining the environment....consider the mentality that thinks it's de rigeur to buy a newly built house every 5 years. The builders oblige that mentality, and the result is the cheap housing development glut that we have today, complete with all the environmental impact that creates--ruined wetlands, longer drives, neighborhoods that REQUIRE that you drive a car for every little thing, etc.
    When you buy a Prius to save money and lower emissions just because you chose to move farther out into a new development that was not at all designed to be eco-friendly, instead of buying in an older, closer neighborhood with local shops you can walk to and a bus line that will take you to work, don't be so smug about it. The Big Picture is bad.
  6. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(Macomb @ Apr 15 2007, 11:15 AM) [snapback]423605[/snapback]</div>
    This is modern myth...it only stimulates alternative fuel markets when it stops the huge consumption of foreign oil. In America, almost as much oil is used to produce E85 since we use corn. It might be beneficial once we convert to cane or cellulosic, but not until then!
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Macomb @ Apr 15 2007, 05:09 AM) [snapback]423336[/snapback]</div>
    No problems as of today does not mean you're safe tomorrow.
    Toyota does not give you any guarantee using E85 fuel.
    There used to be a lot of fire accidents among vehicles using ethanol fuel in Japan.
    Ethanol makes parts corroded unless the vehicle is certified to use it, then you'll see fuel leak here and there.
    Ken@Japan
  8. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(Macomb @ Apr 15 2007, 11:36 AM) [snapback]423631[/snapback]</div>
    I plan on having my Prius 10 years or until the LiI/plug in is available. I don't plan on having to replace the bladder as a normally expected repair.
    Be sure you check out Galaxee's thread on the bladder. You may end up replacing the entire tank/bladder plus some additional lines. Parts and labor will add up as well as the time you're without a car.
    That isn't a normal repair that would be needed in the normal life of the car.
    The question is, when it happens, are you going to pay out of pocket and have it done or sell the car to some unsuspecting buyer without telling them what you did?
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    While I certainly applaud your acceptance of personal responsibility I still question your decision to use E85.
    1)What evidence/science/data do you have to suggest that E85 is safe in the Prius? Seriously, anything other than the fact that you've run a few tanks and haven't yet had a catastrophic failure?
    2)Even if your car makes it 100k miles, this is a car designed to run 200-250k+ miles. When you sell will you fully disclose to the buyer that fact that there maybe unrecognized damage to the various gaskets, seals and hoses due to using E85 in a vehicle clearly not certified for it? I hope your sense of personal responsibility extends that far as well.
  10. Robert Fisher
    Robert Fisher New Member
    53
    Shasta Lake, California
    14 2007, 10:47 AM' Is it not true the "alcohol in the ethanol has a tendency to dry out many of the gaskets, seals and lines when used? If this is factual, then the mod's required to bring the vehicle into an operational mode could be a real hurt, in more ways than one. The approach to insulate the house and use florescent light bulbs would seem more viable concept.
    JCA, all I did was pose a couple of questions on this subject, and was over joyed to receive so many replies. My thanks, and I am sure many others will be thanking, all you responders for the insight in the use of this type of fuel and avoid the heart aches of rotting lines and gaskets. This site is the greatest!
  11. Tideland Prius
    16,681
    Yeah.. well did anyone realise that you're arguing amongst yourselves and he hasn't returned yet?
  12. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 15 2007, 01:06 PM) [snapback]423666[/snapback]</div>
    Yea, I'm pretty sure the OP was just trolling. But Macomb has replied so some of this discussion is directed toward him...mine is anyway.
  13. cc9150
    cc9150 New Member
    44
    <div class='quotetop'>QUOTE(efusco @ Apr 15 2007, 01:46 PM) [snapback]423658[/snapback]</div>
    I see this as absolutely no different from the tire pressure issue. But those who would mess with the tire pressures for their own ends are happy to tell others to butt out, they know what they're doing and take responsibility for it--even when questioned about whether their practices put others on the road in danger.
    I say, leave the poor guy alone. He wants to mess with his car. He doesn't need "evidence/science/data" to do that any more than the tire pressure types do.
  14. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(cc9150 @ Apr 15 2007, 01:51 PM) [snapback]423680[/snapback]</div>
    Absolute NOT the same. We've had posts by automotive tire engineers here in the past absolutely stating that this is NOT a safety issue. The factors involved here are quite clear and the reasons for Toyota's pressure recomendations are well known. Tire pressure within the tire manufacture's specs offer no safety issues and will not lead to any long term damage to the vehicle.
    The E85 thing is clearly different in that it is stated that E85 should not be used in the Prius and that the Prius is not designed for E85. While the exact reasons for this have not been explicitly delineated by Toyota we know from prior problems with a number of other vehicles just exactly what can happen to a car not designed to use E85.
    So, the differences are:
    1)We have experience with the damage that E85 can cause in a car not designed for it's use.
    2)We have clear statements saying NOT to use E85 in Prius.
    3)We have posts by tire engineers saying that higher (within manufacturer specs) will have positive effects on FE and no negative effects on the car (except a rougher ride).
    The poster is the one making the claims that E85 is Ok but presents zero evidence for this. It is my and other's responsibility that are aware of the likely untoward effects to make those clear to both the poster and future readers who might assume that b/c he claims it's OK then that must be true. We need to make it clear that it is, with almost 100% certainty, a bad thing for your car and something you should not due and that it is purely experimental and potentially even unsafe (ie if you have a gas leak and it catches fire and your car explodes).
  15. Robert Fisher
    53
    <div class='quotetop'>QUOTE(efusco @ Apr 15 2007, 11:13 AM) [snapback]423667[/snapback]</div>
    I will assune I am the original OP. If it is me that should have come back with a responce, I thought I did. I apologize. The responce is somewhere among all this, I will have to relocate it.
  16. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(fish @ Apr 15 2007, 02:05 PM) [snapback]423687[/snapback]</div>
    Unless you are also Sithlordmaster you are not the OP I was refering to.
  17. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Just so you can't say you weren't warned, as if you haven't been already - E85 will destroy any number of components in the fuel and emissions system. Period.
    Of course, it's your call. You can try Kerosene or Paint Thinner too if you want.
    If you do want to run an alcohol though, Butanol would be a much better choice.
  18. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Tempus @ Apr 15 2007, 02:14 PM) [snapback]423692[/snapback]</div>
    I think I'll try Jet A next week.... At least Toyota doesn't explicitly say not to use that!
  19. larkinmj
    larkinmj New Member
    1,996
    My concern is not for the OP, wherever he went, or the person who took up his position and is convinced he can run his Prius on E85. If you want to do a science experiment with your own car, go for it. Although if I were the unsuspecting person who bought your Prius off you and ended up spending thousands on repairs as a consequence of your science experiment, I'd get the meanest lawyer I could find to go after you.
    However, many prospective and new buyers come to this website for information and advice. And because the Prius has a non-conventional propulsion system, it is easy to see how someone might be convinced that it could run on ethanol. I have also seen at least one other thread on PC recently where someone claimed he was running his Prius on E85. I hate to think that some innocent but not well-informed Prius owner might destroy his car because he read it was OK to use E85 on PriusChat.
  20. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(sithlord_master @ Apr 14 2007, 10:32 AM) [snapback]423272[/snapback]</div>
    Where in the 2007 OM do you find that E85 is fine?
    To quote from page 319 of the 2007 Owner's Manual,
    "Toyota allows the use of oxygenate blended gasoline where the oxygenate content is up to 10% ethanol or up to 15% MTBE." It says nothing about E85.
    Dave M.
