Should I or Shouldn’t I?
Discussion in 'Prime Main Forum (2017-2022)' started by Acadianer, Apr 8, 2021.
  1. Acadianer
    Acadianer Member
    123
    82
    Technology
    #61 Acadianer, May 14, 2021
  2. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Congrats, and the color is beyond beautiful! :D
    Acadianer likes this.
  3. Acadianer
    Acadianer Member
    123
    82
    Technology
    Thanks
  4. Acadianer
    Acadianer Member
    123
    82
    Technology
    Ahhh, my charging rate might be set lower... and apparently I don’t have access while it’s charging... I’ll check that when I get home haha
  5. Tideland Prius
    16,681
    Public charging is Level 2. Usually 3.3kW or 6.6kW (shared or dedicated but it doesn't matter to us since the Prime only takes 3.3kW).
    Did you want repost the station without the address so that the internet doesn't know where you work?
  6. Acadianer
    Acadianer Member
    123
    82
    Technology
    Where would I change the charging rate? Thought it was easy under the main menu LOL
  7. Tideland Prius
    16,681
    Oh from 8A to 12A? It's via the 4.2" MID
  8. Acadianer
    Acadianer Member
    123
    82
    Technology
    Ahhhh, the option isn’t there when charging. I changed it to MAX. Perfect thank you.
    also set the schedule to charge for 6am, but when I charge other times, I’ll put MAX
    Tideland Prius likes this.
  9. Acadianer
    Acadianer Member
    123
    82
    Technology
    Yeah,
    She’s gonna be a real joy bahahaha. Soo this is over 300mpg average I think? LOL
    jerrymildred likes this.
  10. Tideland Prius
    16,681
    Yeah. You’re going to be pumping a lot less often. If you can charge at home and work, it’ll be months easily.
    Note the first hour charges faster than the second. And of course because our cars have smaller batteries, we should move it when we’re done.
    Acadianer and jerrymildred like this.
  11. Acadianer
    Acadianer Member
    123
    82
    Technology
    I almost wanted to tell them NOT to fill it up before delivering it, less fuel = less weight hauling around for nothing hahaha
    yeah, car will be used daily, so it’s gonna be taken advantaged of.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Don't worry about the weight of the fuel. You would need some kind of engineering/testing equipment with lab conditions to be able to measure the difference in economy between a full and an empty tank. :)
  13. Acadianer
    Acadianer Member
    123
    82
    Technology
    I’m in the civil engineering field. Less weight = less power needed to get moving, but once moving, it’s not that bad. So commuting at constant speeds would render big differences, but in stop and go traffic it would.
    I’m not gonna lose sleep on it for sure though hahaha
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    Curb weight for a 2017 Prime Advanced is 3375 pounds. Gasoline weighs just over six pounds per gallon. So five gallons vs 10 in the tank is a little more than 30 pounds extra weight. Passengers, on the other hand ... :D
  15. Tideland Prius
    16,681
    But then that's 30 lbs over several months :p (or in my case, a year)
    jerrymildred and Acadianer like this.
  16. Acadianer
    Acadianer Member
    123
    82
    Technology
    Maybe I should try losing 30lbs to make up for it hahaha. It might help me get more air on jumps too hehe
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    :D It doesn't look like you can spare 30 pounds. But I know I can spare about 20. :whistle:
  18. Acadianer
    Acadianer Member
    123
    82
    Technology
    Haha, I’m actually hoping to go down about 17lbs this year. I’m at 200lbs right now and I’m 6’ tall, therefore 183cm... would like to be a pound per cm LMAO
  19. Acadianer
    Acadianer Member
    123
    82
    Technology
    So it showed I had 4.5kms left prior to charging. Now it shows 47.5, But isn’t it suppose to be 8.8kWh? Why would it only show 5.44?
  20. Acadianer
    Acadianer Member
    123
    82
    Technology
    I found a level 2 charger for sale on my local marketplace and it has a L15-30P plug. I’m curious, I have a 30a RV outlet on my garage. Can I get an adapter from that outlet to this level 2 charger that would gain my level 2 charging speeds?
