Should I pull the trigger? (from hertz)
Discussion in 'Gen 3 Prius Main Forum' started by CollinPark, Aug 2, 2015.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    could be the tires now on the back are the originals from the front...
    who knows with rentals, I avoid them.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I don't think that is accurate if my Gen2 Prius is an example.
    Firestone would not align the rear tyres and I was annoyed by uneven wear so I took the car to an alignment shop. The rears were shimmed and the problem solved.
    OP: find a Hertz offer with even wear on the tyres and buy that one
  3. CollinPark
    CollinPark Junior Member
    Philadelphia
    monroe website /support/Symptoms/Tire-Wear/ (don't yet have privilege to post websites)
    "Brake Skid / Flat Spot Wear" is how it looks, there's only spot of it, i'm convinced it was during a single event emergency braking possibly on a high way going from 70+ sharp drop to 0. looking at how much rubber it killed...
    buying a rental saves me roughly ~3k compared to buying it from a dealer,
    it's also 1100+ cheaper than the other hertz prii with similar stats
    Dylan Doxey likes this.
  4. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    I have always been leery of buying rental cars for the reasons mentioned above. My daughter bought a used Accord that had been a rental and had no trouble with it. You can do better than $300 per tire! Try Costco
  5. bisco
    52,803
    you're correct. i just didn't want the o/p to think it's easy, buy the car and have the first place he took it tell him it cannot be done. even the dealers won't align the rear end, it takes a qualified shoppe to pull it off correctly.
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Unlike some, I don't completely buy the abused bit about rentals these days, especially compacts like the Prius. I've rented a ton of cars over the years, including in England/Germany, and never drove them any differently than I drive my cars. Well, in Germany I did go a lot faster on the autobahn, but nothing out of sync with other drivers. I believe that even of one thrashes the Prius, the worst that's going to happen is they'll get poor mileage. Even if it was driven all 55,000 miles in PWR mode, there's only so much "thrashing" one can do. The main concern is regular maintenance and on the Prius that amounts to only 5 oil/filter changes. What generally concerns most people is the "high" miles and multiple drivers, but 55,000 on a car that's probably almost 3 years old isn't that bad, we've already got over 32,000 on ours and it's barely a year old.
    I'm suspicious of the tires and surprised that the dealer gave it a clean bill of health. I'm always leery of a car with different front and rear tires unless there's a plausible explanation, like road hazard damage, etc. And standard size tires shouldn't be anywhere near $300 each, maybe $300 to replace both rears. A qualified tire shop should be able to confirm a high-speed stop created flat spot, but I'd hate to buy the car, replace the tires and find there is still a problem. The rental period should give you a better idea of how sound the car is and how it rides with the tires.
  7. Patrick Wong
    18,210
    6,517
    Then there is no point complaining about the worn rear tires. Just replace them. As previously pointed out, if rear wheel alignment is an issue, it must be adjusted by a specialty suspension shop using shims. This is not an approved Toyota service practice.
    I am surprised that Hertz is keeping their cars until 55K miles before selling them. In the not-so-distant past it seemed to me that the major rental car fleets would only log ~30K miles on a vehicle before selling it.
    At least with a rental vehicle there is a high degree of likelihood that the engine oil/oil filter was replaced per the manufacturer's schedule. This cannot always be assumed to be the case with a vehicle owned by a private party.
    Good luck with your decision and the purchase, should you decide to go ahead with that particular choice.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Why is it cheaper ?
    Anyway, your choice: Save $1100 now and hope you did not buy a car with rear alignment/suspension/frame issues, or spend $1100 more to get a car that you have good confidence that none of those issues are present.
    I'm curious -- Does Hertz provide repair and insurance claim history ?
    #28 SageBrush, Aug 2, 2015
  9. bisco
    52,803
    i don't think i've ever rented a car with more than 10,000 miles. but they are always common midsize. maybe they turn those more often.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    That's kind of why I've changed my advice over the years. I use to say..No, don't ever buy a used rental. BUT...the results seem to be proving that advice wrong. I've actually never read a post where someone claimed to of bought a rental vehicle and then had a problem directly related to that reason.
  11. CollinPark
    Philadelphia
    hertz has agreed to replace the rear tires for me free of charge (with the condition that I produce a written statement from a tire shop saying that it's not safe)
    :-] I'll let you guys know in a few months if I come across any problems
    bisco and Blizzard_Persona like this.
  12. bisco
    52,803
    all the best!(y)
  13. Den49
    Den49 Member
    498
    272
    Maryland
    CollinPark- The very likely scenario is that the tires were never rotated which resulted in cupping of the rear tires and the front tires wearing out before the rear tires. There is probably nothing wrong with the car, just lack of tire rotation. I would ask the seller to reduce the price by the cost of two new tires, four new tires if the front tires are more than 25% worn; or, have them install the new tires.
    BTW, my father and other family members have purchased numerous rental cars. None of them have had any problems with them. The reason I don't buy them is they are usually the lower trim models and lack all of the features I want in a car, i.e. Prius level II rather than a level IV. You did a smart thing by having a Toyota dealer do a pre-purchase inspection and should have no reservations about buying this car.
    kenichols29 likes this.
  14. CollinPark
    Philadelphia
    just an update for if anyone ends up on this thread looking for an ex-rental to buy,
    We've had the car for almost half a year now and it runs great, had its 60k maintenance, no problems detected, replaced two wheels, mpg is stable around high 50s in warm weathers low 40s in extreme cold
  15. bisco
    52,803
    thanks for the update, all the best!(y)
  16. Okinawa
    Okinawa Senior Member
    1,333
    320
    I would never buy a rental car. They lead a tough life but that is your call.
  17. BZzap!
    BZzap! Senior Member
    1,607
    878
    My guess about the odd tire wear would be due to front end alignment. To be more precise, the toe- in is off. The rear tires have obviously been on the front at one time or another. The fact that the fronts are different type or brand is not good. You should invest in a complete set of tires. Tire rotation is critical (5000 miles) too. I don't think rental car companies practice due diligence when it comes to proper tire management. Another thing to consider is, a Prius renter is probably going to load the car to the hilt for a long trip with fuel cost in mind. It only takes one cross country trip with under inflated tires to cause significant wear.
    In the long run, I think you are getting a pretty good deal on the car.
  18. CollinPark
    Philadelphia
    Thanks, did allignment after the 2 tire replacement and some of the numbers were ~8 degrees! I really did want to buy a set of 4 tires but wasn't in a financial position to do so, also regrettably decided on ComforTreds instead of TripleTreds (goodyear).
    Its not a good combination because the comfortreads have another layer in its design to absorb shocks and bumps and has fairly high rolling resistance, and the old 2 tires on there are cheap low rolling restance tires. I might replace the old ones with ComforTreds but it just seems so wasteful, they have a lot of treads on them
  19. Sugar Silva
    Sugar Silva Junior Member
    27
    16
    San Diego, Ca
    I would stay away. I rent cars all the time for work and I treat the gas pedal like a drum pedal. I floor it at every light and power brake them numerous times to try and chirp the tires. God help them if they have a hand brake. I can't think I'm the only one who does this.
  20. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    My oe rear tires were cupped when I changed my tires at 40k miles. I had the dealer check the alignment and it was in spec. My tires were wearing funny at 25k and I stopped rotating my tires at 30k miles due to the odd wear and they were, near the end of their life. It might just be the tires. My new tires are wearing normally so I just ble it on the oe goodyears not wearing well at the end of their life span. If I had to guess I would Den49 has it right, they probably didn't rotate the tires enough and the front tires wore out prematurely.
