Should I replace the hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bob nisbet, Sep 4, 2020.
  1. bob nisbet
    bob nisbet Junior Member
    philadelphia
    My 2007 Prius has 145,000 miles. In April I was not driving it, the starter battery ran down, got the Red Triangle and P0A80 code saying the hybrid battery was bad. Then I recharged the starter battery and no problems since. Dr. Prius full battery test has no errors found, All IR normal, battery running warm or normal, upper voltage balance, poor balance block #14. The Life Expectancy test says I have 64% capacity left, fair condition. A friend has a 2004 or 2005 Prius and has dealt with Limp Home Mode, and I don't want to deal with that. I may go to a totally electric car in the next few years, but I still like my 2007. Ideas or Suggestions?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    IF....that 12 V battery is over 4 years old, it probably would be a good idea to change it but I certainly wouldn't mess with the HV one unless you really need to.
    And I personally don't put big bucks or effort into a car that old.....of any brand or type.
    49,380
    consider a grid charger (prolong) or 'newpriusbatteries.com'
