Should I replace the Inverter Pump?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by greengoblin68, Apr 17, 2026.
  1. greengoblin68
    greengoblin68 Junior Member
    DFW Texas
    I just bought a 2008 Prius. It has 168,900 miles. I have detailed CarFax Service Records. It shows the Inverter was serviced by Toyota at 99,800 miles.
    But I really don't know if that means the Inverter Pump has been replaced. Please advise.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,070
    956
    Southern California
    Sign up for a Toyota account and enter the VIN. They may have a record of the last time it was changed.
    greengoblin68 likes this.
  3. JC91006
    16,937
    8,647
    I would wait until you figure out how well the car drives and what other problems arise before changing the inverter pump. Since it's working now, you can wait until the car is completely sorted before changing it. And I would recommend only using Original Toyota parts
    greengoblin68 and Brian1954 like this.
  4. greengoblin68
    DFW Texas
    Wow, I'm getting old. I didn't know there was such a thing.
    I did create an account and it has very detailed records. According to the records Toyota serviced the car. It says found inverter coolant pump malfunction. So they replaced the Inverter Pump.
  5. pasadena_commut
    3,070
    956
    Southern California
    When was it replaced (how many miles and years ago)? If it is over 100k miles you might want to do it proactively, as it sucks when these these go out at an inopportune moment. Only use the OEM pump. Unless you don't mind changing it again.
  6. greengoblin68
    DFW Texas
    It was done at 99,000 miles. It has 168,900 miles on it now.
