Should I replace the transmission fluid on my 2008 Prius with 250k?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Feb 20, 2020.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    interesting. I replaced mine at 216k miles. I don’t know if it was the first time but I suspect it was, and mine was BLACK. Absolutely solid black.
    dig4dirt likes this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    One prius @ 30k and another prius "c" @47k I had super dark almost black. I suppose you could say dark red wine
    Still had a reddish tint, but it looks like bansky's might have been changed before
  3. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    Only the finest red wine for the Prius.
  4. Gen2_Accel
    Gen2_Accel Junior Member
    31
    New Holland, PA
    This guy nailed- motor winding insulation and failure, so go with the Toyota recommended fluid.
  5. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Maxlife LV:$12, walmart
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    From a solution chemistry/solute solvent standpoint, it could possibly be detrimental to change the transmission fluid. If the WS has a maximum saturation point, then you start dissolving more solute into the fresh fluid...
  7. Desert Flier
    Desert Flier Member
    68
    Phoenix
    That's the stuff.
  8. Desert Flier
    Desert Flier Member
    68
    Phoenix
    Quick answer: You will have no problem. Easy job. Everyone is pretty much spot on with advice. The bolts were tight because they haven't been out in 250K miles. Reinstall with a little antiseize and the next guy will thank you. Use just a little because anti seize effects the torque value. I would still torque to 29ft/lbs. Drain it through the drain port. Note that the inverter coolant drain plug is in close proximity. So if you get red coolant instead of transmission fluid you have the wrong plug. Dark with a tinge of red is normal. A few metal particles on the magnet portion of the plug is also normal. Wipe the magnet clean before reinstalling. Use a new crush washer if originally installed and make sure to discard any old washers. Funnel and clear line to fill through the fill port and fill until it overflows. Make sure the car is level before changing the fluid. No clutches or bands in this "transmission" so nothing to worry about when changing fluid. A traditional transmission (non Prius) could sustain failure because the burned fluid and varnish deposits come loose when fresh fluid is introduced (transmission fluid has very strong detergents). So a traditional transmission that was just barely slipping its way through the gears would suffer dire consequences because the little bit of friction surface that remained would be removed by the new fluid and the transmission would then completely slip and fail. We're talking apples and oranges in difference.
  9. Banksy
    415
    132
    Update:
    Changed it weeks ago and it's fine
    Now changing my HV battery using cells from 2nd life batteries.
    Side not that guy is really cool and he obviously really cares about his customers
