Should I reset my gas gauge???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 48mpg, Dec 16, 2015.
  1. 48mpg
    48mpg Member
    193
    46
    florida
    I
    I was down to one light on my gas gauge it was NOT blinking so I knew I still has gas.
    I put in just under 5 gallons ($10) and the gauge now reads full when it should be at about half.
    Should I fill it to the top and reset the gauge?
    (How do I reset the gauge?)
    I don't want to run out if its reading more fuel then it really has ..
    Thanks
  2. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    No Gen 2 Prius in North America has an accurate gas gauge. If you fill up 350 miles after you last filled up, you will be fine. If you always get 48 MPG, 400 miles should be fine.
  3. 48mpg
    48mpg Member
    193
    46
    florida
    I
    ok thanks
  4. 48mpg
    48mpg Member
    193
    46
    florida
    I
    topped it off, the gauge was still on full and it took another 4.3 gallons....so I think its waaaaay off
  5. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    When I had a Gen 2 it could be 40 to 160 miles before the first pip went away, depending on temperature.
  6. 48mpg
    48mpg Member
    193
    46
    florida
    I
    ill just fill up every 350..thanks
  7. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    In defense of Toyota, it really did reduce gasoline vapors quite well, but as you have noticed, at the cost of the driver's sense of security.
