Should I still buy Prius plug-in knowing that I can charge it only once in a while?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by VD101, Oct 24, 2012.
  1. John H
    John H Senior Member
    2,208
    558
    What would that "case" be? I didn't see a post from the OP describing his "case", or daily driving routine.
    I don't charge at home very often, I use the public charging infrastructure, rather extensively. I used 2 gallons of gasoline for my last 3000 miles of driving. The larger battery is a big enabler for higher EV utilization, and lower carbon emissions, as seawolf is quick to point out. If the OP is doing a 300 mile trip between charges, the PiP is probably the more optimal solution, if he is doing 100, the Volt might be, and if 40 then maybe the C-Max, and 13 maybe the PiP again.
  2. lensovet
    2,615
    496
    Burlington, NJ
    well, it is downside from all points, really. health-wise, this means i'm walking less. emissions-wise, unfortunately my power is nowhere near carbon-neutral, so i'm polluting more than before in that sense.
  3. John H
    2,208
    558
    can't you buy carbon free electricity in Berkeley?
    how many kWh can you generate with a bicycle driven genset :)
  4. lensovet
    2,615
    496
    Burlington, NJ
    a) not really (PG&E has some sort of carbon offset program but it's been widely criticized as being more hype than real) and b) i'm charging from my apartment building's laundry room, so i have zero influence on where that power comes from
  5. lensovet
    2,615
    496
    Burlington, NJ
    actually, looks like they cancelled the carbon offset program. this is what's on the table right now: PG&E's Proposed Green Option, but that won't become available until a year from now at the earliest
  6. John H
    2,208
    558
    check out TerraPass | Fight global warming, reduce your carbon footprint
    inexpensive way to shed the guilt, maybe not the pounds though. :)
    you need to get seawolf to calculate your carbon emissions though, TerraPass doesn't figure in EV miles for PHEVs.
  7. jim335
    jim335 Member
    100
    50
    pa
    Now you can go to maryland and buy a plug in for less than a regular prius. $3500 discounted by Toyota. $1500 discount at Darcars Toyota in Frederick , maryland. $2500 tax credit from federal gov. That is $32000 - $7500 or $24500. And zero % financing if you qualify for 60 months, from toyota credit. Sounds too good to be true, but it is true. BTW the plug in gets about 60mpg even when not being plugged in, which is better than regular Prius. You can buy the car in any state you want and still register it where you live. I live in Pa and had to buy mine in Md.
    wjtracy likes this.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    When I picked up my PIP in NY and drove to MI. I got 52MPG
  9. lensovet
    2,615
    496
    Burlington, NJ
    still better than the lift back :)
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    oops! sorry, checked my records:
    4/24/12 373.4 7.44 50.2
    3.899
    50.2MPG
  11. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    ...nice but according to my scorecard, so far lowest price reported so far is $26.5k in Boston
    OK you took the federal discount so you are correct! actually $24K after Fed credit seems possible.
