Should I use up my EV daily for work?
Discussion in 'Prime Fuel Economy & EV Range' started by Sean Shelton, Jan 16, 2020.
  1. Sean Shelton
    Sean Shelton Junior Member
    2020 Prius Prime
    so; My drive to work is around 55 miles and of course 55 miles back. However, it is mostly freeway to freeway. I would say around 2 miles to get to the freeway going to work and 2 miles to get to work when getting off the freeway.
    Most people are saying use HV on the freeway and EV for the rest. That would leave me with a lot of EV still left over before I got home.
    I'm thinking that I should probably use up the EV and charge again when I get home.
    One wrinkle is that it feels like i'm going mostly downhill to work and uphill from work.
    Therefore, i'm thinking (if I have a lot of gas in the tank) that I'll use up the EV going to work and charge it up when I get home.
    Any advice? thanks
  2. schja01
    schja01 Senior Member
    1,858
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    You need to do the math and compare your cost per mile for gas vs electricity in your situation.
    For me I’d need to get 80+ mpg for gasoline to be less costly than electric.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    ^^ +1 ^^
    Unless you have insanely expensive electricity, you're wasting money if you come home with unused EV range. (Assuming you went far enough to use it up.)
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Since you live in CA, I assume your gas price is very high. Depending on what rate of electricity you are getting, and how efficiently you can drive on your daily commute is going to affect the economic.
    I made an Excel spreadsheet to do the calculation for my daily commuting. I live in NE where gas price is relatively cheap but the electric rate is extremely high. For me, driving pure EV cost more than driving HV. However, when I mix HV and EV and get my EV efficiency up (shown by high miles/kWh), I can get better economy and less gas used than pure HV. The result for my 35 miles of daily commute is that it is better to drive HV mixed with EV at high miles/kWh and use about 50% of charge everyday than depleting 100% EV miles at low miles/kWh or driving all HV everyday. This was especially true for my winter driving condition when I need more heating. The difference is quite big, max ~$50 saving in 80 days compared to using up EV, or ~$30 saving compared to using HV only, as you can see on the screen shot of the spreadsheet. I can achieve this saving without using much more gas than using max EV drive (24 gal vs 20.8 gal).
    What is your gas and electricity cost in your area? I can generate the comparison similar to mine for you.
    MSantos likes this.
  5. Sean Shelton
    2020 Prius Prime
    Thanks: Where I live, gas is btw $3.39 and $4, depending on if I make it to Costco: I’m using SCE time of use which is a flat .13 cents during the night which is when I charge.
  6. Salamander_King
    11,024
    8,976
    New England
    With your electric rate, it is going to be easy to say EV drive is far more economical than HV drive. I would try using up all the battery charge at the highest attainable mile/kWh possible.
    Assuming 100 miles commute and charging only at home, using $3.40/gal gas and $0.13/kWh elec. My spread sheet gives those numbers. You probably do not have as much of seasonal fluctuation as I do. Your number maybe mostly summer time, and AC use may affect the EV efficiency bit more.
    Winter Conditions 4 mo (80days drive) HV 53 mpg, EV 4.5miles/kWh, or Full Range HV/EV is based on 8miles/kWh
    MAX EV cost $453.80 gas (gal) 113.58
    MAX HV cost $513.21 gas (gal) 150.94
    Full Range HV/EV mix drive $355.01 gas (gal) 84.53
    Summer Conditions 8 mo (160 days drive) HV 60 mpg, EV 5.5miles/kWh, or Full Range HV/EV is based on 8miles/kWh
    MAX EV cost $767.62 gas (gal) 186.00
    MAX HV cost $906.67 gas (gal) 266.67
    Full Range HV/EV mix drive $321.48 gas (gal) 149.33
    Full Range HV/EV is based on 8miles/kWh of EV efficiency and use all the EV range during trip by mixing HV and EV. It is not easy to attain if you do all >70mph highway drive, but with much slower drive I am currently averaging ~8miles/kWh.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And THAT is the only answer that he really needs.
    Asking the question at all seems a bit odd.
    Why would someone buy a Prime in the first place if you didn't already know that running EV as much as possible is saving you money ??
    Given his stated mileage, the best thing would be to charge at BOTH ends, if he could get a reasonable price on electricity at the "work" end.
    GSK likes this.
  8. Salamander_King
    11,024
    8,976
    New England
    Well, I have been asking that question for 2.5 years now. That's because, if he lives in NE and pays the same price for gas and electricity as I do, he would be spending more by driving EV compared to driving HV all the time. With my shorter distance of commuting it is more economical to drive part EV mixed with HV without depleting the battery charge than drive straight EV discharging all battery charge or straight HV not using battery charge at all. It is also as ecological as maxing out EV drive in terms of gas usage. Turns out even if my electric rate is reduced by 40% to a national average, for my commuting, it is still cheaper overall to drive only partial EV with very high miles/kWh rating, than use all the battery charge at lower efficiency.
    Everyone's situation is different. It is not a simple question to answer.
    MSantos and Tideland Prius like this.
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I don't know how the heat works in the Prime compared to the PIP. But you should use some gas when you want to get the car heated up, in winter.
    Also, to try and be the most optimum I think you want to save a few miles going to work to use at the end of your commute to work and the start to go home when you are on city streets. Try a few different methods and see what uses the least gas, but always use all EV.
    Mike
  10. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    On your commute you could try to use up some of your EV during the city miles and the rest on your slower parts of the highway/in highway traffic. Or put it in EV Auto and see how it uses up your charge (it keeps it in EV until about 72mph, then switches to HV).
    "Using HV on freeway" assumes you will use all EV up before you get home, since HV is more efficient on the highway (as compared to HV in city).
    I have a 40-50 mile commute one way. I do some shorter drives around work sometimes. And then I usually drive around 10 miles going out in the evening. Charging for me during off-peak is about half price compared to using gasoline. I can't charge when I get home from work, because it's peak pricing. So what I do is run it in EV until I get on the highway (about 2 miles, like you), run it in HV on the highway till I get to work. At work, if I drive around, I do it all in EV, so the ICE doesn't have to turn on. I drive home mostly in HV mode on the highway, but I use up some of my EV on the slower parts of the trip (like where the speed limit is 55 instead of 70, or if there's traffic). I try to get home with about 35% charge remaining. Then when I go out at night, I use up that 35% without having to turn on the ICE for the short trips. That's basically my plan - only turn on the ICE on long trips. Use EV on short trips to save wear on the engine. Try to end the day with as close to 0% charge. Charge at night for cheaper rates.
    Sean Shelton likes this.
  11. mistermojorizin
    310
    137
    usa
    2019 Prius Prime
    You don't need to turn on the ICE to get heat in the winter. Just don't use the defrost button. But it only gets down to like 30 degrees here, not like a real winter.
  12. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    True, but from the number's I've seen, very rarely should EV be more expensive than HV, with the most common places where it might are islands (Hawaii, Puerto Rico, etc).
  13. Salamander_King
    11,024
    8,976
    New England
    That may be true for many places on paper by simply comparing pure HV and pure EV. If the driving distance is always less than the max EV range, then the comparison is straightforward. But for a distance longer than the max EV range, it is not as easy to come up with the best strategy to minimize the cost and the gas usage. On top of this, the gas prices are fairly volatile. The electricity rate is regionally and/or seasonally affected. I have not had the same electric rate from month to month. When it comes to analyzing the cost for the use of EV drive in given drive case like my commuting, as I commented above, even if my electricity is at the national average of $0.13/kWh and current gas price of $2.40/gal, my numbers show it is less expensive to drive HV mixed with EV rather than driving purely on gas or max out the EV range.
    #13 Salamander_King, Jan 17, 2020
  14. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    How do you figure that you can get 8 miles/kwh on EV and still get the same 50 for HV? Wouldn't using mostly EV on the efficient sections bring down the average for HV if you're using it on all the inefficient sections of the drive? If you have data to back it up, that would be really interesting and potentially be a big deal for maximizing efficiency. Although I think it's rate for me to do a long enough drive to use all the EV range and also make good use of HV mode. Most of my driving is within or just slightly over the EV range.
    The heat pump works well above freezing. It's very efficient and I don't think it changes the EV vs HV calculation too much. Below freezing I'm not sure. It can have a big impact on EV range. But using the heat makes the engine run longer than it would otherwise, so you'll likely see lower mileage. I still use the heat pump extensively rather than switch to HV, even down to the minimum temperature or in a snowstorm where I need to blast the heat the whole way. The worst I've seen is about 16 miles of EV range blasting the heat on my commute in a snowstorm. EV driving is cleaner, so even if it costs slightly more it's worthwhile to me. I pay for "100% wind" power, so in theory my electricity usage is more sustainable than using gas. In practice it's hard to wrap my head around how that works, because it all comes from the same grid, but I think it helps. The car is so cheap to drive whether on gas or electric that the cost of fuel hardly matters to me.
    Another consideration for HV vs EV is letting the engine warm up. I think it's not the best for the engine to let it run for just a short time on a regular basis. It will always complete the warm-up cycle unless you turn the car off before it's done, but the warm up cycle the minimum, not necessarily enough to get everything fully up to operating temperature. For example if I have just slightly less EV range than I need to make it to my destination, I might use HV the whole way. But maybe it doesn't matter too much?
  15. Salamander_King
    11,024
    8,976
    New England
    Yes, there are some guess works at play here. As you know it is not easy to determine the real HV portion of mpg on PRIME when EV mode is mixed in. But if I can keep the EV range fairly constant for the same distance commute, in my case total ~35 miles, the overall mpg displayed on the car should be proportional to pure HV mpg regardless of how EV portion is mixed into the 35 miles. Compared to the monthly log data from the first year Nov-Jan to this winter Nov-Jan, I am getting almost the same monthly average mpg yet vastly different miles/kWh. During my first winter, I never used HV/EV switch at all. I just drove EV until the car ran out of EV SOC then rest was just HV. During those days I determined my true EV range in my winter was ~20miles on continuous EV mode drive. This winter, I was always switching HV/EV during my commute, but have a set point when I do the switching, so the sum of the segments I have the car in EV mode can be calculated. This distance is about 20 miles in total. So, having a similar EV distance in the same 35 miles commute route and resulting similar overall mpg must mean HV portion of mpg is also very similar.
  16. 3PriusMike
    3,101
    2,421
    Silicon Valley
    My point about using HV when you want heat is more the case where your total trip length is going to be beyond the EV range anyway.
    This way you are getting the advantage of the ICE waste heat and can use the battery EV range for driving.
    Mike
  17. Sean Shelton
    2020 Prius Prime
    great advice. Thank You
  18. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    If you are in SoCal and SCE is your electricity provider, then the $$/mile is about the same whether you drive in EV or HV,
    It's about $0.05/mile whether driving HV or EV mode.
  19. Salamander_King
    11,024
    8,976
    New England
    OP said he is paying "gas is btw $3.39 and $4, depending on if I make it to Costco: I’m using SCE time of use which is a flat .13 cents during the night which is when I charge". At that rate, EV is much better choice at ~$0.034/mile. In comarison HV for gas at $3.39/gal will be at ~$0.063/mile.
    utsug likes this.
  20. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Wonder why OP couldn't figure that out when he had all the data he needed to calculate $$/mile. ???
    I just drive and don't think too much about this. And charge the battery as often as possible.
    Salamander_King likes this.
