Should I use up my EV daily for work?
Discussion in 'Prime Fuel Economy & EV Range' started by Sean Shelton, Jan 16, 2020.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    I agree, that is the best strategy. That being said, there are some special situations that requires more thinking if you want to maximize saving $$$ and still doing good for the environment. ;)
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You are obviously not qualified to be a "real" hybrid owner.
    No paranoia.
    No OCD.
    No overwhelming curiosity about insignificant minutiae.
    :ROFLMAO::ROFLMAO:
  3. Sean Shelton
    Sean Shelton Junior Member
    2020 Prius Prime
    I have SCE time of use (TOU) now which about 0.11835 kwh which is saving about $50-60 on what my bill rose to when I first bought the car ans was a tiered rate; I basically made the lost to get the feedback and some user formulas and calculations;
    I wish the car had better driving range on EV like 80 to 100 would be nice; Maybe the new 2021-2022 cars will have 100 mile range; There are a lot of EV cars coming out so i’m worried hybrids will not get the stickers in the future too;
  4. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Well, SCE ($1500 rebate), CA state ($1000 rebate) and Fed ($4000+ tax credit) did qualify me as a PHEV owner!
  5. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    I have almost the same commute as yours. Mine is 100 miles RT and about 3 miles to fwy. In my situation, I try to use up all my EV miles since there is a free LADWP charging station near my work (0.6 miles walk). Going to work is mostly downhill, so out of 50 miles, 45 miles are in EV and 5 miles in HV mode.
    Use plugshare app to find charging station near your work place.
  6. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    In California gasoline and electricity are both expensive, and they cost about the same to run a Prius Prime.
    I definitely prefer EV for short trips, as otherwise an engine that doesn't fully warm up will have shorter longevity and more breakdowns in the long run.
    The way I would run it in OP's case is that I wouldn't use the charge fully in the first leg of the trip so that I don't idle the engine in the parking structure. Likewise, I would leave about 2% charge when I make it home so that I don't idle the engine in the driveway and garage. This should not only save fuel but reduce emissions and noise.
  7. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Another way to think of it: a ratio.
    Assume 55 mpg for HV mode and a conservative 4 miles/kWh. That means a gallon of gasoline will move you the same distance as 13.75 kWh. That means as long as a kWh is less than the price of gasoline divided by 13.75, electric driving is less expensive.
    Here in Los Angeles I can get gas at Costco for about 3.09. With those figures above any electricity that is $0.22/kWh or less makes EV travel less expensive than gasoline.
  8. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    yikes. math.
    luckily i charge at home and at work for free...lol
    and only a 12.5 mile commute one way.
    so most days i make it to work and back on a single charge. even in winter.
    when i am cold i turn on HV to warm up car faster, and burn some gas.
    feels strange to me to have the TRANS and engine spinning in ice cold ATF.
    anyone move to make their commute ideal? aka less than 30 miles one way?
    or round trip?
  9. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The transmission is spinning no matter what. It has very few moving parts, and it should never wear out.
  10. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    yes i know its spinning, but does the fluid warm up ? or does it even need to warm up ?
    i'm using old ICE trannys as a baseline, they got hot, and fluid was designed like motor oil to perform when hot.
    aka warmed up.
    i'm sure its probably fine in the prime, but old habits die hard. lol
    i just kinda like knowing everything is warmed up.
    so when its freezing out, i dont mind flipping over to HV for 15 minutes to warm up the cabin
    and the engine /trans
  11. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    It doesn't have friction plates like a traditional automatic transmission. Just planetary gears (and some kind of one way clutch for the engine). It's closer to a differential than a transmission.
    But I think the motors are cooled by transmission fluid, so in that case it probably heats up quite a bit.
    benagi likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    As @m8547 said, the transaxle creates quite a bit of heat with all the gears spinning and the big electric motors running, which is why it needs to be cooled. (Electric motors get HOT!!)
    Here's the video with all the details how it works.
    And here's the tldnr version
  13. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Yes, the OP should use up his EV daily for work or anything else!
    Don't even think about it. Just drive.
